Results 1 to 8 of 8
Thread: Where Can I Get A 2.5 Inch Backflush Hose?
    May 2015
    Moorpark, CA
    171
    My Pentair 2000 DE filter has a 2.5 inch OD pipe outlet for back flushing. I have only found 1.5 and 2 inch hoses. Where can I find a 2.5" hose?
    Michael
    20,000 gallon in-ground gunite/plaster pool (1992), attached spa with spillway, Pentair Superflo 1.5 HP pump, Smith booster pump for pool sweep, Pentair 2000 DE filter, Sta Rite Max-E-Therm 400 heater, Silencer Blower 2 HP for spa, Polaris 280 pool sweep.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Where Can I Get A 2.5 Inch Backflush Hose?
    Your filter's waste port is probably dual diameter, 2" ID, 2" OD. Glue a threaded bushing in it and screw in a hose fitting. That's how mine is set up.
    Shop LASCO 2-in Dia x 1-1/2-in Dia PVC Sch 40 Bushing at Lowes.com
    Shop Aqua EZ Hose Adapter at Lowes.com
    May 2015
    Moorpark, CA
    171
    Richard, you hit the nail on the head with the size of my fitting. Thanks for the all the part numbers. That's perfect. I'll head over to Lowe's for the parts as soon as I can.
    I'm still scratching my head as to how the previous owner's pool person backwashed the filter. If he left it with no hose, it appears the backwash water would drain right into the pool!
    Michael
    Isaac-1's Avatar
    SW Louisiana
    6,711
    My suggestion is to get an old fire hose off ebay, you can often find ones that are past their certification date (15-20 years I think) that spent their entire lives in a fire cabinet never being used for under $50, sometimes under $20. They are far more robust than the not so cheap flimsy blue hoses.
    May 2015
    Moorpark, CA
    171
    Quote Originally Posted by Isaac-1 View Post
    Thanks for the idea Isaac. How would you connect a fire hose to the filter?
    Michael
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    They make fittings to go from pipe thread to a fire hose fitting. Probably be as much as the hose since they are brass. Just cut the end off and use a hose clamp like the regular backwash hose.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The adapters are fairly reasonable ($15-$25 for most on ebay, search NPT NST), the only issue is there is more than one standard of fire hose fittings, although the most common is NST (same as NH) which is National Thread, there are others you may find particularly in older hoses as some major cities kept their legacy non standard connectors for a VERY long time, some like NYC of CH may still have the legacy hoses, I am not sure. Or course there is also the alternative of removing / cutting off the connector and just attaching it with a host clamp.
    Ike
    May 2015
    Moorpark, CA
    171
    Thanks, guys!
    Michael
