Thread: How to wire a mastertemp heater
    I had my pool redone. the old pool had a simple pump and a simple heater. I had both wired to a single intermatic timer. The timer turned on and killed the power to both at the same time. A fireman switch shut off the heat a few minutes ahead of time. Probably the way most are wired.
    The new pool has an Intelliflow pump and a Mastertemp 400 heater. The pump has its own internal timer. The heater does not. I do not have an intellitouch system. The new heater seems a little more sophisticated than the old one. I have the heater is controlled by an intermatic timer with a fireman switch.
    Finally my question. Currently I have the the timer shut off power to the heater. The fireman switch is used to cut off the heat a few minutes before the power. Alternatively, I could also wire it to leave power on to the heater and just use the fireman switch to control the heat.
    Any thoughts on which would be better? Killing the power is always safest. I an unsure if the heater is best left powered.
    Thanks
    gunite free-form pool, black onyx plaster, 30000 gal, pentair Quad DE 60
    salt water with intellichlor 40
    intelliflo pump, pentair Mastertemp 400 heater, polaris 180
    waterfall on a separate system, hayward 3/4 horse pump
    ps0303's Avatar
    Jul 2011
    FL
    3,699
    Re: How to wire a mastertemp heater
    Depending on where you live, keeping power on to the heater when not needed can cause critters at times to crawl inside during the coolers times. They look for the warmth of the transformer. Plus if you're not using it, why have it powered up. I think of it this way, do you leave the lights on in all of your rooms of the house even when you're not in the room? I always instruct the users to power the unit off at the heater if they do not have automation. If they do have automation, I wire the unit to only get power when heat is called for.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Critters I never thought of. The heater is inside a workshop but mice can get anywhere. That's a good reason to leave it the way it is. thanks.
    I second your WORD OF CAUTION. I have a relative who is an electrician and taught me much over the years. I don't know any plumbers. Water leaks are annoying, Gas leaks blow up. I call a plumber.
