Thread: In wall skimmer panty hose
    poolsam's Avatar
    Jun 2014
    Bangor, maine
    66
    Anyone uding cheap knee high pantyhose in their skimmers. I have a in walll Hayward and wondering how you keep the hose secure around the filter.
    Intex 15X48 metal frame - 4400 gallons - 8 years old!
    Intex SWG / Pump (sanitation) / Hayward pump (sand filter & heater)
    Hayward skimmer / Hayward Propane Heater 100,000 BTU / Hayward S144T Sand Filter
    Jan 2012
    'burbs of Augusta, Georgia
    7,239
    Re: In wall skimmer panty hose
    I'm not sure how Intex skimmers look, but I use skimmer socks inside my in ground pool skimmer. Mine stretches over the edge if the skimmer basket and the handle clips back down into the basket which helps to secure it inside the skimmer basket. Then the pull of the water pressure keeps the sock pulled down into the basket. With the socks I just pull it out, replace with another and then shake out/hose out the debris in the first and let it dry until the next time I clean out the basket.
    Apr 2015
    East Wenatchee WA
    39
    Pony tail holder over sock on outside of basket!!
    15'x30' oval AGP. 12000 gal. 1 HP pentair pump. 19 inch sand filter.
    Auto vacuum thing that works through skimmer. Solar cover.
    OLD 400ish gallon Cal Spa hot tub with two new pumps (ouch)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Does it not have a basket? Skimmer Sock/Nylon Illustrated
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    You Rookies!..............I'm a QUEEN size kinda guy myself. I just tie the legs in knots and then stretch the waist over my wide mouth basket.
