Thread: Bought a new house, Pool Leaks, need advice! Please!!
    Jun 2015
    Bedford hills ny
    46
    Hello all.
    I bought a new home that has an old gunite pool (at least 10 years old... Maybe 50, I have no clue).
    We tried to fill the pool but it would get 2/3rds full then it leaked as fast as we could fill it. Once we took the hose out it maintained that level.
    I decided to drain, clean/scrub out the pool and noticed a few things.
    1) there is a caulked joint around the bottom of the pool where the sides meet the bottom
    2) there appears to be a crack in the pool
    3) the pool appeared to fil to the level of a light that was clearly leaking but struggled to pass it
    i am trying to replace and re-seal the light
    what is the joint? Should I replace it? It appears there is either caulk or epoxy on top of older caulking? Should I replace all of it? In some areas the caulked area appears wide (1.5" instead of 1/2") should I patch that?
    should I treat the crack as a problem?
    should I do all three or one at a time? I have gone to the problem of creating a clean dry pool.... Should I attack all three?
    thank you
    20' x 50' AG gunite pool (no idea on gallons) built a long time ago. DE Filter w/Hayward Pump. Well water.
    Jun 2015
    Bedford hills ny
    46
    Re: Bought a new house, Pool Leaks, need advice! Please!!
    I have tried to attach a few more pictures but appear to have hit my limit.
