Results 1 to 9 of 9
Thread: Adding Chemicals
    Apr 2015
    Katy, TX
    65
    Adding Chemicals
    From what I have read on the forum, I'm supposed to add chemicals near the return jets. Do I need to add it around EACH return jet or can I just add the chemicals to ONE return jet near the deep end of the pool. I hate to waste my time and go around each return jet if I do not have to.
    24K gallon, IG, plaster, Pentair Clean and Clear Plus Filter, Pentair Heater, Pentair Intelliflo pump, Built in March 2015, Taylor K-2006, Spa included
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Adding Chemicals
    Adding it in front of one return jet is fine - that's what I've done since converting to the TFP method nearly 4 years ago with great results.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Here is a handy Pool School article that discusses pool chemicals and how to add them. Pool School - Recommended Pool Chemicals
    Z7What's Avatar
    Mar 2015
    New Orleans Area
    141
    Quote Originally Posted by pooldv View Post
    I know I read that entire page but missed the line about pouring it in front of a jet. The 2 months I been doing the TFPC Method I just throw it into the middle of the pool. Would someone care to explain why its suggested to pour it slowly in front of a jet?
    Wayne
    24'X54" Round 15,000 Gallon Pool
    Pentair SD-60 Sand Filter With 1.5HP Pump & Center Floor Drain
    Lil' Shark Vacuum With Leaf Canister
    New TFPC User And Couldn't Be Happier
    Pool School + Test Kit + Pool Math = A Perfect Trouble Free Pool
    30,403
    To keep it from settling on the bottom of your pool. You want to mix it as quickly and evenly as possible.
    Z7What's Avatar
    Mar 2015
    New Orleans Area
    141
    So the bleach will actually sink to the bottom some what?
    Wayne
    30,403
    Keep in mind that is a general rule for ALL chemistry additions, but, yes, uncirculated bleach will tend to collect at the bottom of your pool.
    Apr 2015
    Katy, TX
    65
    Do you recommend that we brush the pool in the area that we dropped the chemical?
    30,403
    Quote Originally Posted by Brian T View Post
    Not really. Just apply them so the return jet distributes them into the pool and there is no need. If you see granules on your pool floor, by all means brush them around until they are gone.
