Results 1 to 12 of 12
Thread: A slide??
    May 2013
    East Granby CT
    4
    A slide??
    I know that it is not recommended, but who has a slide on their above ground pool? If you do what brand/model is it and height or rough idea of dimensions? I want to do it for the kids(ya right) but the misses and I butt heads on the safety aspect.
    We (ugh..hum..ugh.. I) built the deck a little bit larger to accommodate some play things so I always envisioned having one. The shorter kid friendly ones seem ideal but maybe a full size would work. What are the general opinions? and as always everyone loves pictures right?!! Talking about a 5 and soon to be 8 yr old that swim daily from open to closing time.
    Thanks in advance
    What we're dealing with
    17k-ish gallon, 27'x 52" A/G, 150'Cartridge Filter, 1 hp pump, DIY Install spring 2013
    Apr 2013
    Argyle, TX
    77
    Re: A slide??
    You have a lovely set up there.
    Good luck with the slide the kids will love it.
    Do a YouTube search and there are a few examples
    Is that a CAT hiding behind the deck?
    Orlando, FL
    690
    Re: A slide??
    Here's one DYI Pool Slide
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    linda1's Avatar
    Mar 2010
    Western Pa.
    297
    Re: A slide??
    We bought a used Zoomerang slide last year. Our deck is 4 feet wide and we can squeeze by the slide. Here is the link to pictures I posted last year.
    http://www.troublefreepool.com/threa...ieds-for-deals
    30 ft. round Conquest agp, 19,800 gal; Pentair Easy Clean 1 hp DE EC60 filter system
    Hayward H250N gas heater; TF100 Test Kit
    2 Fafco 4x20 sunsaver solar bear solar panels
    Dolphin E 10 ~ Zoomerang slide
    Majestic 8000 Above-Ground Pool Step
    May 2013
    East Granby CT
    4
    Re: A slide??
    Thanks for the responses.
    Yes that's my old skid steer behind the pool. I am fortunate to have access to equipment to do the bulk of the heavy work.
    I have a cool playscape slide that could be neat but building a wooden frame and ladder wouldn't likely hold up to my two.
    I have been searching on Craig's list looking but am not willing to travel too far. A bunch of the small slides have come up but all have been 2+ hrs away.
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    Re: A slide??
    Hi Litchfield, We installed a slide similar to those you see posted in our above ground years ago and the kids loved it. So when we had our inground built we had them install one. I understand your misses concern, but in my opinion it's safer than when kids (and adults) try to headlong dives into a 4' pool. The angle is shallow enough your not heading butting the bottom. The kids have slid feet first on their backs and face forward on their bellies with no problems.
    One thing I would add, the inground slide has water lines to keep the slide wet, which makes it a much faster ride. It feeds pool water via the pump to the slide, so that's is something to consider if you could make that work.
    In the end it comes down to setting rules as it is with anything around pools. ( the only problem we ever had with the slide was the teenagers who thought they could stand up and surf their way down the slide) Needless to say that ended the moment I saw it. I think you folks would enjoy it and you know the kids would. Good luck with the project...... and the Misses
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Re: A slide??
    After all, go to a water park. How deep are the pools at the end of slides there? 3 feet at most?
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    jbriggs1219's Avatar
    Apr 2015
    Brunswick/Ohio
    77
    Re: A slide??
    I have the Sr Smith rogue 2 on my deck for above ground pool....I made sure to call my insurance company to make sure it was ok...they said no problem...shocked me...my 5 year old and his friends all love it...handles up to 250lbs...so adults love it too....Think it was $1500 on Amazon...we've gone down it every way imaginable and never had a problem...obviously just make sure to bolt it in to good support under the deck..I used pvc to connect it off the pump so constant water flow without affecting the cya or chlorine in pool...best investment for fun in pool for kids...and adults...I'll post a pic soon
    13,500 gallon AG
    Cartridge Filter
    Raypak Natural Gas Heater
    Apr 2015
    Brunswick/Ohio
    77
    Re: A slide??
    [IMG][/IMG]
    13,500 gallon AG
    Cartridge Filter
    Apr 2015
    Brunswick/Ohio
    77
    Re: A slide??
    The hard part is trying to dunk when you're going down on your belly
    13,500 gallon AG
    Cartridge Filter
    Apr 2015
    Brunswick/Ohio
    77
    Re: A slide??
    13,500 gallon AG
    Cartridge Filter
    lefty51's Avatar
    May 2015
    451
    Re: A slide??
    Quote Originally Posted by jbriggs1219 View Post
    Sent from my HTC6525LVW using Tapatalk
    Amen to that. I see your goal is by the slide to. Seems to bring the air Jordan in them !
