Thread: Drain connection on Intex above ground pool
    Does anyone know where to get a connector so I can hook up a hose to one of the drain holes in my Intex above ground pool. It has one on either side about 2 or 3 inches above the ground. It has a cap that threads over it on the outside and a plug the pushes in from the inside. The outside thread is bigger than a garden hose and I have no idea what type of connection it is. I'd like to attache a hose to it so I can drain the last 10-12 inches of water out. I was able to siphon most of it but not that last bit. Anyone got any ideas?
    (: Jan :)
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    892
    Re: Drain connection on Intex above ground pool
    When I drained my old intex...I used a pump and ran it to the street not out into the yard...it is a small pump used for floor drains in basements...I would just submerge it on the bottom of the pool and made sure that it stood straight up...It would take it down to just about a 1/4 to 1/2 inch in the bottom...
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    Been a while since you posted this, but in case you or anyone else needs the drain hose adapter...
    http://www.coolinflatables.com/product/10184
    Intex Metal Frame 18'x9'x52" Oval Above Ground ~5000 gal. Hayward Sand Filter. Hayward 1.5 hp pump. Sungrabber 2x20 solar heating panel.
