Results 1 to 7 of 7
Thread: R0013 CYA Refill & Salt Lv TestKit
    Jul 2014
    Dallas, Tx
    20
    Howdy, guys.
    Got a quick a couple of question here. Ran out R0013 CYA solution from TF100 TestKit. I would like to purchase a refill. I would like to know if I could get Taylor R0013-C instead?
    Regarding salt level test, what do you guys think to get a testkit, or strips is good enough? I mean, it's for myself, and I dont really need to have very exact reading.
    Thanks in advance for your suggestions.
    32 ft x 25 ft x (4.5 ft ~ 8.0 ft) 30k gallon pool || AquaPure Model APUREM SWG || Pentair MiniMaxPlus Electronic Ignition Heater || Pentair FNS Plus 60 D.E Filter || TFTestKits TF-100
    PoolMathCalc
    Jul 2014
    Dallas, Tx
    20
    TF100 CYA R0013 Refill and Salt Level Test suggestion.
    Howdy, guys.
    (Sorry, I posted this thread in another section as well.)
    Duplicate threads merged together.
    PoolMathCalc
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: R0013 CYA Refill & Salt Lv TestKit
    They're the same stuff. But all the refills are available at TFTestkits.net
    The C is just the bottle size.
    A = .75 oz (22 mL B = 2 oz (60 mL, wide-mouth),
    C = 2 oz (60 mL), D = 4 oz, DD = 8 oz, DB = dropper bottle, E = 16 oz, F = 32 oz,
    G = gal,
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    Re: TF100 CYA R0013 Refill and Salt Level Test suggestion.
    For reagent refills I'd go right to TFTestkits.net and order there.
    I use the Taylor drop test kit (K1776) and get a consistent reading. Recently I tried a strip from a friend's new bottle and the reading was wayyyyyy off. Like half the salt.
    I've heard the salt strips are the most reliable of any of the chemistry strips, but I sure couldn't believe it.
    Jul 2014
    Dallas, Tx
    20
    much appreciate it.
    What about salt level test? will you recommend strips or kit, please?
    PoolMathCalc
    Jul 2014
    Dallas, Tx
    20
    Quote Originally Posted by YippeeSkippy View Post
    Thank you so much, Skippy.
    The reason I asked is because i do have some rewards for Leslie's. Unfortunately, they do not carry any salt level test kit except for strips
    PoolMathCalc
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I have the Taylor K1766 salt test kit. I highly recommend it. Nothing better than having reliable test results and the 1776 provides it
    Divin Dave,
