Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Pool concrete around pool complete. Pool needs cleaning. But how??
    ashmoussa's Avatar
    Sep 2014
    Jefferson (Lake Hopatcong), NJ
    113
    Hi TFP,
    So the first phase of the pool patio around the pool, the concrete base, is now complete but a lot of the concrete dust and stuff is in the pool now. I was maintaining the pool crystal clear , thanks to TFP! But now the pool is cloudy. Few questions:
    1. The concrete guys started this morning and I had to leave prior to them finishing and I did not get the low down on how to cure(??) the concrete. Am I supposed to water it everyday or something??
    2. Now that I have a mess inside the pool water, how do I clean it???? Can/should I run this junk through my DE filter? Help plz.
    3. Is it normal to have a little gap between the plastic skimmer rings and the concrete? My water is a little high due to heavy rains and the water is seeping through the skimmer extension rings.
    P.S.: I will be installing pavers over the concrete
    May 2015: 17K Viking Caribbean Fiberglass IG pool (16'x40'), PAL lighting three 2T4 LED's (inside pool), Hayward DE 6020, Hayward Ecostar VS pump, SWG TCell15, Hayward HP21404T Heat Pump, Hayward Omnilogic automation + Sense & Dispense (HLCHEM).
    Rest of the backyard ideas/wish list: 12 x 20 Pergola, 48" Round Firepit, Accent/Landscape lighting, Outdoor movie theatre and music (projector & speakers), etc...
    30,395
    Re: Pool concrete around pool complete. Pool needs cleaning. But how??
    1. Never a bad idea to water down new concrete....especially in the hot summer. I would water it.
    2. Do you have a manual vacuum or robot?
    3. I don't know what the skimmer rings are.
    ashmoussa's Avatar
    Sep 2014
    113
    1. That's what I thought. But for how long and how often?
    2. I have a manual vacuum through the skimmer. No robot.
    3. When I add the pavers on top of the concrete, I will need to put an extension ring. It will not lineup with the existing base piece of the skimmer and it would leave a gap where water would be able to go around and out of the skimmer. This is what's happening now. I don't know if I made sense. Pleas see pic. ImageUploadedByTapatalk1433628870.934374.jpg
    ashmoussa's Avatar
    Sep 2014
    113
    Here's a better picture showing what I mean. It doesn't lineup. Normal??ImageUploadedByTapatalk1433629083.115660.jpg
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,797
    Usually the concrete is poured flush up to the skimmer extension. And they didn't do the best job on yours making it uniform given that they didn't go flush. I would pull up the extension, use a small grinder with diamond blade and hit hat jagged section. Then you can caulk the gap and it will look nice.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    30,395
    Couple of days, as often as you like, but 2-3 times daily would certainly be adequate. It's not very critical unless your temps are 90 +.
    ashmoussa's Avatar
    Sep 2014
    113
    Thanks. How about cleaning the pool of all that concrete dust?? I tried sweeping it into a corner but the water is still cloudy. Thx for the help in advance.
    kimdurg's Avatar
    May 2014
    North Canton, Ohio
    45
    When they poured my new concrete, they did it before I opened the pool (took winter cover off, but I put the old solar cover on, knowing I was replacing it this year). They also poured the concrete up to the extension and my extension fits inside the old skimmer, instead of outside it like your picture is showing.
    20K gal; vinyl in-ground; 1.5HP Hayward pump; Hayward Sand Filter; Well water; K-2006.
    ashmoussa's Avatar
    Sep 2014
    113
    The PB is supposed to come back after the concrete pour to "open/clean" the pool. Hopefully, this happens soon. I am afraid to run all this **** through my pump and filter.
    As for the skimmer, I contacted the concrete guy and sent him some pictures. He has not gotten back to me yet. We shall see where I get with him.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,733
    Look for a skimmer extension collar. That will take care of the gap
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    ashmoussa's Avatar
    Sep 2014
    113
    Quote Originally Posted by bdavis466 View Post
    Do they have extension rings that are adjustable to fit any "angle/slant"?? The make of the skimmer is "Waterway".
    Thx.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,733
    The rings are pretty generic as far as sizing goes since most skimmers use the same lids. As far as the slant is concerned, you may have to grind it to be able to sit at the angle you need. This skimmer has three extensions plus the ring for the lid. This too is a Waterway skimmer.
    -Brian-
    POOL BUILD
    Mar 2015
    Las Vegas NV
    460
    Just poured my deck yesterday, my concrete guy asked me not to water. Since he's warranting the work I'm following his directions. I'd call your guy and ask.
    SUMMER 2015 BUILD IG gunite 38 x 31, 28,000 gal, 110' perimeter, Intelliflo VS, Whisperflow 3hp, Intellibrite LED x2, Clean & Clear 520, Screen Logic, Intelichlor 40, Quartzscape Blue, K-2006C, Speedstir, Aquanaut 400 (4 wheel The Pool Cleaner)
    ashmoussa's Avatar
    Sep 2014
    113
    I'm going to have the PB open/clean the pool this week. I hope he doesn't use my pump and filter to do so. How do they typically clean after concrete pours?? Do they use their own robotic cleaners or something?
    I'm also going to ask him about the skimmer and see what he says he'll do to fix it.
    ashmoussa's Avatar
    Sep 2014
    113
    Quote Originally Posted by QingGuy View Post
    Hmmm. I guess I'll call the concrete guy and ask what he recommends. Thanks.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Do you not have a valve between the pump and filter that can be used to divert water out of the pool??
    If you had one, you could vacuum to waste with your pool vacuum. Thats what I did.
    Divin Dave,
    ashmoussa's Avatar
    Sep 2014
    113
    Quote Originally Posted by Divin Dave View Post
    Hi Dave,
    I have a multi valve that has to waste but doesn't the dirty water still go through the pump?? I'm afraid the concrete would have an ill effect on the pump.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Ok then, you can certainly vacuum it to waste.
    concrete is nothing but small pebbles, sand and mortar, the pump will handle that just fine. I probably vacuumed out 10 to 15 gallons of concrete out of the bottom of my pool after the deck was poured.
    If the PB comes to do it, I bet money that he would use your pump and do the same thing.
    Quote Originally Posted by ashmoussa View Post
    Hi Dave,
    Divin Dave,
    ashmoussa's Avatar
    Sep 2014
    113
    Thanks Dave for the reassurance.
  20. Back To Top    #20
    ashmoussa's Avatar
    Sep 2014
    113
    Chemistry to start off my reply:
    FC: 3.5
    CC: 0.5
    CA: 425 or 275 (see below for explanation)
    PH: 7.6
    So the PB came out to do an opening and they were floored and in shock!!! They said that they could not believe their eyes! I asked why? They said they were stocked up on all sorts of chemicals to go to war on my pool's water, thinking that it would have definitely been a swamp since the pool was installed May 8th. I could not help but take a bow, literally, and say that I learned it all from TFP and I asked them to NOT add anything to the pool without me checking it first. And they were like "huh?" I didn't feel like explaining. lol
    I hadn't put any salt to the pool so they added salt by the name of: "Splash Pool Salt - packaged for BUCKMAN'S" It says ... designed for use with salt water chlorine generators, no additives. Any thoughts??
    My system says low salt level (2700) after about 5 hours of filter running. They may have to add more. Or I'll just run out and get some. At this "minimum" level is the chlorine being generated?? How do I know for sure???
    They then proceeded to test my pool water and they were shocked again. They said everything was right on target except for calcium. I took another bow, haha!! And told them to just give me the calcium and I would add it later. The guy left me the calcium. He said it was 70. He measured it with a Taylor kit. I tested it with my T-100 kit and got 275. How is it sooo different??? But then again, when I tested it twice in a row for s..ts and giggles, from the same water sample, I got, first time 425 and the second time 275
    As for cleaning the concrete debris from the pool, the PB used a vacuum to waste. Dave you were right!! Thanks!!!
    They are coming out tomorrow to do Pool School with me. lol ... Should I ask the PB for anything or mention anything to him? What kind of questions should I be asking?
    Thoughts? Comments? Concerns? Thanks TFP community!!!
