Thread: Can Dirty DE Filter Cause Filter Element or Pump Damage?
    May 2015
    Moorpark, CA
    171
    New to pools. Filter pressure has gone from 16 to 21 in one day after SLAMing. I'm worried that this dirty filter will ruin the Pentair 2000 DE filter elements or the pump due to the load. I am still moving out of my old house, so I can't do anything about this for another day or two.
    Let me know if I should turn the pump off.
    Michael
    20,000 gallon in-ground gunite/plaster pool (1992), attached spa with spillway, Pentair Superflo 1.5 HP pump, Smith booster pump for pool sweep, Pentair 2000 DE filter, Sta Rite Max-E-Therm 400 heater, Silencer Blower 2 HP for spa, Polaris 280 pool sweep.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Can Dirty DE Filter Cause Filter Element or Pump Damage?
    It's unlikely the pump can generate enough pressure to crush the grids. What the filter really wants is a backwash. If you have no time, you have no time. If you have a multiport valve, set it to recirculate. If you don't, you might as well shut the thing off. You probably have lousy circulation right now anyway.
    May 2015
    Moorpark, CA
    171
    Thanks, Richard.
    I've noticed the circulation is way down. Hopefully, tomorrow I can do my first backwash.
    Michael
