Thread: Question about running the filter during shocking
    Jun 2015
    Los Angeles, CA
    4
    Hi there!
    Haven't had a problem for years with my pool, (follow troublefreepool program) however I guess I slipped and I have a slight bloom of green algae on the steps. Beginning shock treatment today.
    Just curious to know if it's absolutely essential to run the filter *continuously* during shocking, and what the real benefits are for doing that. Is it possible to run just for a portion of the days (for example -throughout the day, but not at night) ? The reason I ask, is that the electric bill is going to KILL me ($$$) next month if I run the pump continuously for a few days.
    Has anyone tried shocking and just running the pump for several hours during each day with success? (8-10 hours a day for example?).
    Thanks in advance!
    John
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Re: Question about running the filter during shocking
    It will slow your SLAM down and cost you in bleach and time.
    Kim
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    It is sort of necessary. Not so much for filtering but for circulation. When the bleach kills the algae, there's no more bleach in that area. And if the water is not circulating, no fresh bleach gets moved in to replace it. So whatever algae is left in the localized area gets a free ride and can reproduce.
    Get right on that algae and brush the $#!? out of it. The faster you kill it, the faster the SLAM is over, and the sooner you can revert to a normal filter schedule. If it's just some patches on the floor, it could be just a matter of a day or two.
    Jun 2015
    Los Angeles, CA
    4
    Cool Re: Question about running the filter during shocking
    OK, great! Understood, and makes sense. Thanks for the replies! It is much appreciated - especially on a Saturday.
    Kind regards,
    John.
