Results 1 to 11 of 11
Thread: Replacing horizontal beam and t-fitting in summer escape
    Apr 2015
    New Bedford, MA
    65
    After taking the pool cover off we noticed 1 section was bent from the heavy snow. Right now we are draining the pool because my husband thought it was a great idea to put wood planks that had paint on them across the pool and now paint clippings all over the pool..so I'm reading if I empty the pool the liner will shrink can I replace the beam and the horizontal beam while the pool is full? Or does it need to be drained?uploadfromtaptalk1433613686159.jpguploadfromtaptalk1433613715001.jpg
    14x42 summer escape metal frame pool with 2800 gph intex sand filter pump
    summer scape metal frame AG pool 14x42, 3750 gallons
    INTEX Krystal Clear 2800 GPH sand filter pump
    TF-100 Test Kit Pool Calculator , cya-chart
    Pool school,recommended-levels
    Aug 2013
    south east Arizona
    197
    Re: Replacing horizontal beam and t-fitting in summer escape
    looks like it is drained now?
    somewhere around 6,800 gal 18 x 4 foot round Intex Ultra Frame AG, finished filling August 29, 2013. toy pump w/ "A" cartridge up and running next day --- July 2015 upgraded to Krystal Clear 3000 GPH pump and 16" sand filter --- May 2016 Intex auto cleaner and in July salt system and Hayward skimmer
    Apr 2015
    New Bedford, MA
    65
    I want to try to fill it as soon as possible but if it needs to be empty to replace them then I won't fill it until I get the pieces
    Aug 2013
    south east Arizona
    197
    ah, sorry! I didn't get it. yeah, I probably would have suggested waiting to drain until you had the part in hand. you might be able to put a few inches in, but yes it needs to be pretty empty to dismantle the frame.
    these pools are designed to be taken down over winter so I would think getting it out of the sun would be good enough in terms of the shrinkage issue. That is mostly for thin vinyl liners in walled pools. now if your liner is really old it may have problems but they would probably happen anyway.
    Apr 2015
    New Bedford, MA
    65
    Ok so you think I'm ok with just waiting it's only a year old when they talked about vinyl I thought they meant all.. Is it possible to just take that section off or would I need to dismantle the whole pool?
    Jul 2014
    Oakbank, Canada
    389
    You will be able to take just that one section off, no problem.
    Quote Originally Posted by angelover02740 View Post
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Apr 2015
    New Bedford, MA
    65
    Quote Originally Posted by DarrelB View Post
    Ok thanks..empty or full
    Aug 2013
    south east Arizona
    197
    oh just the section you need to replace, and no I would not fill it until you fix the frame. they are pretty tough pools, but why risk more damage or even ruining it? I would try to make sure it doesn't bake in the sun too much or blow around in the wind, so a few inches of water to keep it in place is fine. maybe lay some old sheets over the sides to protect from the sun. (I have no idea how intense the sun is in MA, where I am it is INTENSE)
    I did just see somebody else with a "home repair" of a rail, let me see if I can find that.
    found it - Intex rusted horizontal beam
    Apr 2015
    New Bedford, MA
    65
    Summer is taking its time to come this week it's suppose to be mid 70s and last week was only 60 for a high
    Jul 2014
    Oakbank, Canada
    389
    Empty of course. I was going to mention that in the post, but you already said you had drained the pool, so I thought "why state the obvious". If you only have few inches, I would not worry about it.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I'd add at least an inch or two of water, to hold it down in case a big wind comes through. It might blow away....
