Page 1 of 3 123 LastLast
Results 1 to 20 of 56
Thread: Solar Installation
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Solar Installation
    Do you have to drill a hole in the 3 port diverter valve so the panels drain down to pool? I have been reading everthing i could find, and that came up, it said Compol solar valve has it already, but i want to use a Janfy... Thank you
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    38,548
    Re: Solar Installation
    Pentair also has a solar 3 way with a check valve in it. You only might need the hole to help drain if you have a controller that turns off the solar valve when the pump shuts off.
    38,548
    You can also add a "bypass" between the solar supply and return pipes where they go up to the roof.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    A bypass is another option that lets you control things somewhat, I went this way in conjunction with a drain valve.
    The red valve is set to allow just a small bypass trickle, enough to slowly drain the section going up to the panels when the pump is off. You may also note the wire tied to the lever style drain valve. This wire was added after a small limb fell one night and bumped the valve partly open draining several inches of water from the pool. The pool equipment including the diverter valve is indoors behind the wall seen here.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Is there a problem leaving water in the panels when not in use? I guess it would get to hot without being circulated...
    Autopilot SWG
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    The solar sensor, I need about 30 feet to reach my panels, can I buy 15 ft and splice another section black & red wire I have some the same type...Thanks
    Autopilot SWG
    Jun 2015
    Dothan, AL
    5
    Quote Originally Posted by boston62 View Post
    The reason is more with allowing the water to drain out so it doesn't get too cold or freeze in the panels.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You can splice in an additional length on the sensor, just use a good marine grade splice that will not corrode and seal it with watertight splicing tape. This is important as corrosion in the connection will increase resistance of the circuit and result in false temperature readings.
    Ike
    p.s. another alternative would be to use gel splices like are used on phone lines
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Yes I seen those they are round you put the two wires in and press the button down. Thank you
    Autopilot SWG
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    I have 3 panels on one side of my roof i want to split it to the othrr side with 5 panels would i use 2" sched 40 pvc to split it over? Thanks
    Autopilot SWG
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Photos or a sketch would help here
    Jun 2014
    Roseville, CA
    345
    I would not close the valve all the way. You will probably hear it start to drain, Just leave it there as an "off" position rather than "hard off" like a faucet. When "off" your pump may push water a few feet up the pipe depending on head pressure, but it won't fill the cells.
    It looks like when your system is off, both sides should drain OK. At least that's the plan A.
    Plan B would be to add a vacuum break at the highest place in the panel system. But those can be tricky.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    I read i should drill a 1/4" hole in the diverter valve for draining when the pump shuts off..you ever hear of this? I think Pentair sells a 3 port solar valve with the hole it I use Jandy though. Thanks to everyone for the help, will post photo of what i am doing..
    Autopilot SWG
    38,548
    Yes, there are many threads discussing adding a hole, 1/4" is likely even bigger than you need.
    Do you already have the solar 3-way installed? If not, then just use one that has the check valve built in.
    And there is nothing mysterious or complicated about installing a VRV (vacuum release valve). You do need one to prevent a vacuum when the pump turns off causing damage to the cells. It can go just about anywhere in the system.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    I do have a VRV in the top left panel, I will post a picture...Thanks jblizzle
    Autopilot SWG
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    There are pics of my solar setup and plumbing in my build thread in my sig. If you are looking for more pics.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Would you put shut off valves in the solar system?
    Autopilot SWG
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Yes, you never know when it may spring a leak.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    You think just on the supply line only to the solar?
    Autopilot SWG
  20. Back To Top    #20
    38,548
    I have no shut-off valves. Just the 3-way on the supply and the check valve on the return. I have a drain valve open all winter on the roof and never had any water up there, so they much be doing a good enough job isolating the solar.
