Thread: high TA and low CH
    Jun 2015
    waterford MI
    2
    high TA and low CH
    Hi
    I have issue with high TA(175) and low CH(175) .
    I have lowered PH to 7.0 and I keep it this way for 3 days and I don't see any changes in TA. I know that to raise CH I have to add some calcium chloride (I will ASAP) but TA seems to be frozen. I keep fighting with that pool for a while and water remains to be cloudy.
    starting to have enough of it. This is a inground plaster pool that have been painted with some pool paint by previous owner,
    have old gravel/sand filter (replaced sand last year),
    use trichlor as sanitizer(FC=15, CC=0.5)I keep chlorine high to remove that cloudiness,
    current PH=7.1
    CYA=48
    any suggestions what else can I try?
    Thanks in advance
    Chris.
    27700 gal plaster pool painted with pool paint, gravel/sand filter(unknown brand or capacity(no labels)), trichlor feeder,
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: high TA and low CH
    What are the details of your pool?
    Have you read this article re your TA? Pool School - Lower Total Alkalinity
    The pucks you are using are acidic and keeping the pH from rising probably.
    You are already getting near the top end of CYA for a non-SWG pool, so you should probably stop using them.
    But, if the pool is cloudy I would SLAM it ip using liquid chlorine. Pool School - SLAM - Shock Level And Maintain
    Support the site
    Jun 2015
    waterford MI
    2
    Thanks for answer!
    I'll try to stop trichlor for a while and will use liquid to SLAM it and see what happens.
    since it is cloudy and FC is so high I understand that my PH reading on FAS-DPD test may be off?
    I'm aerating it with water splashing into it from return ans with air.
    Thanks.
