Results 1 to 7 of 7
Thread: If you see some algae but numbers are good?
    Aug 2014
    East Northport, NY
    155
    Hi.
    My last test was seemingly ok but this AM I noticed a very small but definitively spot of Algae. Do I have to do a slam to get rid of it? I would rather not but not sure.
    Thanks!
    FC - 6
    CC - 0
    TA - 120
    PH - 7.5
    CYA - 35
    IG Vinyl -30,000 (20x40)
    Hayward Pro Grid DE Filter/Hayward rebuilt 1 HP Pump
    AutoPilot DIG-220 RC52 SWCG
    TF-100 Test Kit
    Aquabot Bravo
    Jun 2014
    14,990
    Re: If you see some algae but numbers are good?
    I would think ....SLAM! You see it, do it now to get it done quicker. Afterwards though, I believe your CYA should be much higher for a SWG pool (70-80). Maybe something to consider.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    At the very least scrub it off with a brush.
    If it's in a corner, see what you can do to improve circulation in that area.
    30,403
    After the above, I would carry your FC up around 8-10 ppm for a couple of days to make sure the algae doesn't reappear.
    Aug 2014
    East Northport, NY
    155
    I'm going to brush and hit boost on the SWG
    TF-100 Test Kit
    Aquabot Bravo
    Casey's Avatar
    SW PA
    10,423
    Please raise your CYA. It needs to be higher. And brush the pool thoroughly weekly.
    Aug 2014
    East Northport, NY
    155
    I know the CYA is an issue - need to fill another sock!
    TF-100 Test Kit
    Aquabot Bravo
