Thread: what and how do folks landscape around intex pools?
    Aug 2013
    south east Arizona
    197
    Hello all,
    Finally thinking about the OUTSIDE of my little pool. I was looking for some photos showing details of the ground but I am not great at searching this site. I would like to have stepping stones set in gravel or some kind of mulch over weed cloth. how do people handle the point of contact at the very bottom of the pool?
    With a regular walled pool you don't have to worry about gravel going under the liner but I am not sure what to do with the rounded and exposed bottom of the intex. do you use some kind of lawn edging or indoor baseboard material? does the top edge rub on the liner? in front of the legs or between legs and liner? staked in? (scares me to have things like that near the liner)
    would river or other rounded rocks work instead?
    is some other "mulch" material good instead of gravel? I know about the rubber shreddy stuff, don't know if it is available or even useful in Arizona but if so, does it have problems with blowing in the wind or is it actually heavier than it looks?
    I know there is a slide show somewhere but I can't seem to find it? maybe my pop-up blocker is messing with it? there is a largish blank space in the upper center of the home page with a tiny dark rectangle on the lower right that I can't seem to get to enlarge. Is that the slide show? are there many intex pools included?
    Thanks in advance for any help, advice, links.
    somewhere around 6,800 gal 18 x 4 foot round Intex Ultra Frame AG, finished filling August 29, 2013. toy pump w/ "A" cartridge up and running next day --- July 2015 upgraded to Krystal Clear 3000 GPH pump and 16" sand filter --- May 2016 Intex auto cleaner and in July salt system and Hayward skimmer
    Jul 2014
    Oakbank, Canada
    389
    Re: what and how do folks landscape around intex pools?
    Everyone uses something different, to ones own taste. I ended up just using some sand around the edge, with ground cloth under it. I could not bring my self to put stones (round or not) near the liner.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    May 2015
    Fishers/Indiana
    5
    Try looking on Pinterest. I found some interesting ideas there. Good luck!
