Results 1 to 7 of 7
Thread: No power/generating light on Hayward Aqua Rite SWG
    Victor's Avatar
    Girard, OH
    38
    Hello all, was doing my checks this morning on my pool and I noticed my power light and generating light are not "on" on my swg. I checked the manual and it said try replacing fuse, which I did and no luck.
    Readings are
    87
    8.7
    0.00
    51p
    -0
    AL-0
    R 1.58
    T-15
    I added some bleach since my FC was at 2, any ideas??
    Thanks in advance
    Victor
    IG, steel walled vinyl liner, approx. 18000 gal. swg ( Hayward salt system), gas heated, with 250 lb sand filter and 1.5 horse pump.
    Jun 2011
    Long Beach, CA
    2,778
    Re: No power/generating light on Hayward Aqua Rite SWG
    It could be the current limiter has gone bad. It is a $3 part and can be replaced very easily by anyone who has any type of soldering skills. Do a search for "current limiter" and many articles will pop up.
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Also, is the SWG plugged into a different outlet than your filter? Your GFCI could have tripped.
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    Victor's Avatar
    Girard, OH
    38
    ImageUploadedByTapatalk1433618136.196080.jpg this seems to be the problem like what was said, it seems to be cracked and when I touch it both lights come back on.....
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Good day, not sure on the age of the unit. You might try calling our tech line about the unit. Could have anywhere from a 1 or 3 year warranty depending on installation. 908-355-7995
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Jun 2015
    Plano
    2
    Mouser has these for about $18.00 with shipping. http://www.mouser.com/Search/Product...995-AS32-2R025
    Victor's Avatar
    Girard, OH
    38
    Thanks, I actually called Hayward and board was still covered!! So it's replaced and running!!!
