Thread: Does Rubbing TriChlor Puck on Stain Really Work?
    May 2015
    Moorpark, CA
    171
    I rubbed a Trichlor puck on a stain, leaving a white film on it. 20 minutes later, I came back, and the white Trichlor was gone, but the stain was still there. Has anyone successfully used the procedure on a stain?
    Michael
    20,000 gallon in-ground gunite/plaster pool (1992), attached spa with spillway, Pentair Superflo 1.5 HP pump, Smith booster pump for pool sweep, Pentair 2000 DE filter, Sta Rite Max-E-Therm 400 heater, Silencer Blower 2 HP for spa, Polaris 280 pool sweep.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Does Rubbing TriChlor Puck on Stain Really Work?
    This only works if the stain is organic.
    Pick up a cheap vitamin C tablet and put it on the stain. Vitamin C will remove/lighten metal stains.
    Support the site
    JoyfulNoise's Avatar
    May 2015
    13,176
    I agree a vitamin C tablet (ascorbic acid) is the cheapest approach to stain id. If you are still confused by the stain, there is a product called Jack's Magic Stain ID kit that can help to identify a stain. They are a bit pricey so I would do the trichlor puck test (careful, trichlor is very acidic and you don't want to leave it on plaster for very long), then ascorbic acid tablet and then get the kit if the first two tests fail.
    Matt
    May 2015
    Moorpark, CA
    171
    Has anyone actually had success at rubbing the Trichlor, or is it so dangerous to the plaster, no one has tried?
    Michael
    May 2015
    Moorpark, CA
    171
    blank
