Results 1 to 11 of 11
Thread: Test strips say no chlorine
    Jun 2015
    Walkersville MD
    48
    Hello. We had a professional open our pool 4 days ago. He put in 2 bags of shock. We tested the next day and it read no chlorine. We added 4 3" pucks, tested the next day, still nothing. Since then, we have added 2 full 121 oz jugs of 8% bleach. Still not registering any chlorine. It hasn't even been that hot or sunny. Everything else on the test strip is within normal ranges (ph, etc). Now what?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: Test strips say no chlorine
    You need your own quality test kit. Test stirs are bad on a good day.
    If the chlorine level is too high the strip can bleach out and show no FC. So, you either have no chlorine or very high chlorine.
    I recomend you order a TF100 today. TFTestkits.net
    Support the site
    Skitch's Avatar
    May 2015
    Athens, Georgia
    112
    Now purchase a recommended test kit and post your results.
    Either a Taylor K-2006 or a TF-100
    18,400 gallon 28' round above ground pool sand filter 2013 K-2006 2014 new Hayward pump 2018
    My pool turned green the second year, K-2006 saved me, Trouble Free Pool set me free
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I am sorry but we really can't tell much from those test strips, they are at best one step better than a Ouji board
    Jun 2015
    Walkersville MD
    48
    Oh man now I'm scared I've put 10 times as much chlorine in as I should have! I know we have a better testing kit around here I just can't find it at the moment. I'll report back as soon as I do. Also - the water looks almost too blue. Is that a sign of something? Thank you all for your suggestions.
    May 2014
    Franklin, NC
    9,187
    Quote Originally Posted by Bec2854 View Post
    If you got the test kit at a pool store or other store the limit of the chlorine test is probably 5ppm.
    You really do want the kit we recomend.
    No, too blue is not a sign of anything I know of.
    If you did over chlorinate it will come down in a couple of days.
    Support the site
    Jun 2015
    Walkersville MD
    48
    So both of the kits recommended look like they are around $50-$60. Is there a more budget friendly option?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Not really. A TF100 and the XL option will get you free shipping and carry you through this season and probably most of next year as well. Go hang out at the pool store tomorrow and see how much people are spending there on generally useless chemicals and bad advice and weigh the difference.
    30,426
    Bec2854,
    What folks above are saying is we will teach you and you will learn to manage your pool yourself. You can keep the money you paid to the folks to open your pool, you can keep the money the Pool Store will talk you in to.
    BUT..... Almost everything we teach begins with accurate and dependable test results........there is no substitute. So the "budget-friendly" strips don't work and neither will the "free" testing you get at the pool store.
    Take charge of your pool....don't let others do it for you. To start that, you will have to give the forum the kind of precise numbers it needs to help you.
    Read through the many threads on here.....you'll be a believer.
    Donldson's Avatar
    NW Ohio
    2,905
    First, welcome to TFP!
    Simply put, would you pay $50 to save $500? I'm not joking since that is about what I am saving a year by not running the overpriced chlorinator we had or shocking weekly or doing any of the stuff we used to do with our pool. It is also kind of nice that our water is way clearer than before too. It literally saved me money to get better water quality. That is what TFPC does.
    It is your pool and your call. I am just offering my own experience as an example.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jun 2015
    Walkersville MD
    48
    Okay so there is definitely chlorine in there! I found the other test kit we bought last year (hth 6 way test kit) and tested while I wait for my Taylor K-2006 to arrive and chlorine matched somewhere between 2 and 10 ppm (all those shades of yellow look the same to me). I really hope this new kit is easier to read! Thanks all for your help!
