Results 1 to 15 of 15
Thread: How to connect hose to vacuum pool?
    Jun 2015
    Arenzville/ IL
    12
    So my pool is a grain silo ring put in the ground lol it has one skimmer and the skimmer only has one hole in it. Do I need a special plate to put in there to attach a hose? http://imgur.com/a/Q13id This is the pool, it looks way better than this after I shocked the **** out of it though. I can take pics of the skimmer if someone needs that.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,432
    Re: How to connect hose to vacuum pool?
    There are skimmer plates. Here is a link to show you some of the different ones.
    skimmer vacuum plates - Google Search
    Kim
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    A picture might help, if we can see through the water to the bottom of the skimmer.
    I found a threaded PVC pipe coupling that slips into the hole in my skimmer without going past the internal lip. The vacuum hose is a snug fit in the threaded end. Works perfect for me. Almost too much suction.
    Jun 2015
    Arenzville/ IL
    12
    http://i.imgur.com/KpCvG2c.jpg Picture is not too good but theirs only one hole in there but to the left their looks to be another piece that looks like a plug?
    Richard320's Avatar
    Jan 2010
    18,967
    It's quite common to have the main drain plumbed to the skimmer, so there will be two ports. If the pool isn't plumbed that way, they plug the unused port. You can try finding something like I did or use a vacuum plate. The vacuum plate's actually not a bad idea, because it can sit above the basket and catch most of the debris before it gets to the pump strainer. Just measure the diameter of the skimmer opening and get one that fits. http://www.lowes.com/pd_2435-1003-VP_0__?productId=3027674
    Jun 2015
    Arenzville/ IL
    12
    I will try that, thanks! The pool is looking a ton better now. Just need to get the vacuum and all that going. http://imgur.com/TVf1E2f
    Jul 2012
    Tallahassee, FL
    30,432
    You have made some awesome progress! Good job!
    Kim
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    I use a vac plate too it helps to catch the finer stuff and can still use the filter sock. My only problem is the suction pressure cracked my plate. I still use it cracked.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    For those of us with main drains plumbed to the skimmer, does the flying saucer water diverter stay in, or should we pull out the diverter?
    I can put my vacuum hose into the main suction port at the bottom of the skimmer, but I use a skimmer plate so the skimmer basket and sock can catch more of the crud instead of the pump strainer. Was just curious about whether or not to leave the diverter in place or not.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by jrs_diesel View Post
    You'll have to experiment and find out. I tried vacuuming with the diverter in place and it didn't work. The pump had the choice between pulling water up through a relatively short fat pipe or a long, twisted narrow hose and the gap between the vacuum head and the floor. The main drain won and it didn't vacuum worth beans.
    Jun 2015
    Arenzville/ IL
    12
    Is it possible to just plug directly into the skimmers one port if I submerge the line first? I will get a plate if needed though I don't wanna damage my new pump/filter. I just wondered if I submerge the hose and get the air out then plug into the one skimmer port it could work? I also need to find out what other chemicals to add. I have a little test strip deal they left behind that looks old as ****. Has two eye droppers of stuff with a small double vialed measureed piece but I have no idea what any of those measurements mean lol.
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by Dedshark View Post
    Yes. That's what I do. However, I don't get a lot of debris blown into my pool, mostly just dust, so clogging the pipes with a wad of soggy leaves isn't a huge worry for me. Others may not be so fortunate.
    Spend the money and invest in a proper test kit. You'll love being in control.
    Jun 2015
    Arenzville/ IL
    12
    Well I have a nice big pile of leaves in the bottom of the pool I need to clean up, maybe I should wait until I get a plate so I can keep the skimmer in.
    Jul 2012
    Tallahassee, FL
    30,432
    You can also get a leaf rake like this
    Academy - INTEX Leaf Rake
    Kim
    Jun 2015
    Arenzville/ IL
    12
    Quote Originally Posted by kimkats View Post
    Kim
    Thanks!
