Results 1 to 16 of 16
Thread: It's all about the water
    SCon36's Avatar
    Jul 2014
    Bedford, KY
    121
    I took this picture two weeks or so ago. I've done very little to my pool over the last few weeks yet my water still looks this good. Other than an occasional vac and then adding bleach, all I've done is enjoy the pool. I invite you to share pics of your clear water here too!
    SCon36
    24,000 Gallon IG vinyl pool (16x36x8) with Hayward S200 sand filter and Hayward pump and heat pump. Built August 2011. I use a Taylor K-2005 test kit with a K-1515 add on.
    https://www.youtube.com/watch?v=bIgL...0MyAw&index=29
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: It's all about the water
    It doesn't get any better than that.
    SO, you are saying you just used Bleach to get the water Clear like that?
    Essential Links:
    Jun 2014
    15,027
    That looks great!
    SCon36's Avatar
    Jul 2014
    Bedford, KY
    121
    Quote Originally Posted by Patrick_B View Post
    The cheapest 8.25 I could find.
    SCon36
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    You don't actually let people in that cesspool do you?
    You pour bleach in it? And acid? OMG!! It's a miracle everyone's skin hasn't just peeled off!
    SCon36's Avatar
    Jul 2014
    Bedford, KY
    121
    My kids don't get a sunburn. They get chemical burns.
    SCon36
    awtrizzle's Avatar
    Apr 2015
    Chesapeake/ Virginia
    293
    I also do very little to my pool. Ever since I got it cleaned up it has been very easy to maintain. The Polaris actually helps too!!
    Twinkle twinkle little pool - YouTube
    14.5k gallon IG, Vinyl Liner, Hayward SuperPump (1HP 220v motor), Hayward DE Filter
    Polaris Booster Pump, 2 skimmers and one bottom drain, 5 returns.
    ~My Tremendous SLAM thread~
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by awtrizzle View Post
    Where's the diving board?
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    awtrizzle's Avatar
    Apr 2015
    293
    It was in very bad shape. I ripped it off during the SLAM/cleanup and haven't put anything in its place yet. Still haven't figured out what I want to do. If I want to just do a regular diving board or if I want to do something different.
    Casey's Avatar
    SW PA
    10,427
    Here's mine last week right be for a storm blew through.
    Jun 2014
    Houston, Texas
    475
    Quote Originally Posted by SCon36 View Post
    I would if I could figure out how to post pics!
    19k SW IG
    Wet Edge pebble tech = new 5/16 (replaster)
    Hayward variable speed pump (new 6/17) /Shark for cleaning
    New - filled 10/18/14 - TFP 100 test kit
    awtrizzle's Avatar
    Apr 2015
    293
    Jun 2015
    Phoenix, AZ
    216
    Quote Originally Posted by DMS2014 View Post
    I use Imgur - very easy -
    -- Just create an account
    -- Drag / Drop your images
    -- Copy the URL
    -- Paste the URL in this forum.
    Check out my build thread (link) for sample pics - The pictures also render very well in smartphones and tablets.
    2015 build (link)| 16.5 K gal | Salt Water | IG rect | 35'x16' | 568 sf | 105 ft peri | depth 3'-5' | PV3 in-floor | 2 Venturi skimmers | MDX+SDX drains | T-CELL-15 SWG | Hayward Ecostar VS pump | Hayward 7220 DE Filter | Aqua Cal Icebreaker Heat / Cool pump SQ166 | Hayward Sense & Dispense PH Controller| Omnilogic | Pebble Sheen Blue Surf | Ultra UV | Stenner acid pump | Coverstar Automatic | TF-100
    Jul 2010
    IL
    201
    24' AGP Sentinelle 54" , 1hp 2 speed power-flo matrix, New 250K to replace the 150k BTU heater, pool roover Jr. Aqua Trol SWG, Large deck, taylor k-2006, Majestic Stairs with colored LED, COLD BEER
    awtrizzle's Avatar
    Apr 2015
    293
    Nice.
    christied48's Avatar
    Aug 2013
    Allen, TX
    89
    sparklin!
    24K gallon IG Stonescapes, Jandy VS pump, cartridge filter
