Results 1 to 12 of 12
Thread: To SLAM or not to SLAM
    ixp9276's Avatar
    Jun 2015
    Honeoye Falls
    7
    Hello,
    I'm new to TFP and my first thought is to SLAM my pool to get started.
    On the other hand, my TF-100 numbers don't seem too bad (other than low chlorine and high TA):
    FC=0.5
    CC=0
    TC=0.5
    CH=275
    TA=160
    CYA=60
    No algae, water is a bit blue.
    Should I SLAM or just get the FC level up to 3ppm?
    Thanks
    30K gal, 20x40 ft, IG Vinyl, 1.5 HP pump, 120 sqft cartridge, TF-100 Test Kit, 16 mil solar blanket
    Jun 2014
    15,023
    Re: To SLAM or not to SLAM
    Welcome! The following link had a good post on blue water. Give it a read and see if it still applies to you.
    Why is my water blue?
    PS - Don't let that CYA creep-up on you any higher. You're not using any tablets right?
    Yes- Definitely get that FC up to the minimum 3!
    By the way, what was your PH? I didn't see that above. And TA will need to come down a bit too. See the Recommend Levels chart below in my link.
    ixp9276's Avatar
    Jun 2015
    Honeoye Falls
    7
    I just stopped using tablets. Switched to bleach.
    I did just add Kleen Pool algaecide about a month ago. That could be the reason for the water looking blue; a bit of copper.
    Would you recommend that I empty 1/2 the pool to get rid of the copper?
    pH 7.5
    Jun 2014
    15,023
    I'll have to let our mineral experts reply to that question about copper. Glad you pulled the pucks though!
    I did find this previous post though: Copper Green pool
    Also, another one just in case: Pool School - Metals in the Water and Metal Stains
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP!
    How long has the chlorine been below the minimum level for your CYA? Chlorine CYA Chart That is when algae starts growing.
    Maybe Pool School - Perform the Overnight FC Loss Test (OCLT) to see if there is organic matter growing in your pool consuming chlorine.
    ixp9276's Avatar
    Jun 2015
    Honeoye Falls
    7
    Thanks pooldv. Thats a good idea. I'll test tonight to see what's going on,
    ixp9276's Avatar
    Jun 2015
    Honeoye Falls
    7
    Hi there.
    The overnight chlorine loss test passed as it went from 5ppm to 4ppm of FC with CC at 0.5ppm for both readings in a 9 hour period between 9PM and 6AM. It seems that there is no need to SLAM.
    Can someone verify that I need to keep my FC level at 8ppm with my CYA at 70? It seems high. Also my daily K-1000 chlorine test that came with the TS-100 test kit does not go that high. Does that mean that I have to use the FAS/DPD test daily?
    Thanks for you help !
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by ixp9276 View Post
    Hi there.
    You have just discovered one of the pitfalls of maintaining a pool with high CYA -- the chlorine testing.
    Yes, you'll need to use the FAS-DPD every day for a while. Eventually, you'll know pretty much what results you'll see before you test, and at that point you can just dump in the usual amount and test every other day. Your minimum FC is 5, so you target 8 so it stays above 5 until the next time you test and add. Eventually, you'll also be able to just glance at the OTO test and ensure you're above the highest reading and add the usual.
    You've reached a new level of intimacy with your pool chemistry. Don't rush the relationship, take the time to get to know it through frequent testing.
    ixp9276's Avatar
    Jun 2015
    Honeoye Falls
    7
    Thank you all for your help! I'll keep an eye on the FC for the next few weeks to keep it between 5-8ppm. I only had to add 46 oz this morning (12.5% Cl) as it had drifted down to 6.5ppm since my last Cl addition. Next season I'll try to lower the CYA.
    What are your thoughts on using a solar cover with that much chlorine in the water?
    Thanks again!
    Richard320's Avatar
    Jan 2010
    18,967
    Thanks again!
    It's no big deal. The actual aggressive chlorine is less than you're allowed in tap water with no CYA in it. That's why you can step in wearing a colored swimsuit and not step out in a white one. I've swam around underwater with my eyes open in 20 FC before. CYA was over 200, so it was no problem.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    agreed Richard. im at CYA of 60 with FC at 11 currently. I can swim and open my eyes in the water, no burning. pH is at 7.5
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    ixp9276's Avatar
    Jun 2015
    Honeoye Falls
    7
    Thanks Richard, Danin. I'll put the solar cover back on and try to warm up the pool. The water temp has been around 70F - a bit chili but feels good to get in with such clear water now!
    Thanks
    Ivan
