Thread: stair coping issue
    Apr 2015
    Brookline
    60
    stair coping issue
    I have posted some pictures to help me figure out the stair/coping issue. If i install per manufacture recommendation i will have quite a lip when entering the pool. If i make the coping flush i will have an air pocket between stairs and coping. If i pull the stairs forward away from the wall, i will have 1/2 gap between walls and front of stairs for the liner to get stretched out to. Help!
    Southern New Hampshire, 18x36 single roman end pool.
    Feb 2014
    Upstate, NY
    390
    Re: stair coping issue
    Doesn't the coping go higher ?? I'm looking at the last photo. It appears there is a little lip that the coping rests on.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Apr 2015
    Brookline
    60
    It did go higher, just got done installing. Figured it out. You can go much higher due to the liner.
    Feb 2014
    Upstate, NY
    390
    Excellent !!
