Thread: Intex metal frame leak at floor edge seal
    poolsam's Avatar
    Jun 2014
    Bangor, maine
    66
    Pool drops about 2 inches a day, the leak is from an areas where the floor seals to the wall vinyl. It is visibly lifted in one areas. Am going to drain pool to fix this. Should I patch it, or just use vinyl cement inside the seam and stick it back together... With the seam ridges not sure how a patch will stick...
    Intex 15X48 metal frame - 4400 gallons - 8 years old!
    Intex SWG / Pump (sanitation) / Hayward pump (sand filter & heater)
    Hayward skimmer / Hayward Propane Heater 100,000 BTU / Hayward S144T Sand Filter
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Re: Intex metal frame leak at floor edge seal
    IMO, with an 8 year old Intex, you are asking for problem after problem to start emerging. I would at the least get a new liner.
    http://www.troublefreepool.com/threa...18-metal-frame
    Liners as cheap as $60.
    http://www.poolzone.com/Pool-Liners/...p-Pool-Liners/
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Yep, I'd say you got your money's worth.
