Thread: Safe to swim with high FC
    Mar 2015
    Charlotte, NC
    8
    That is very sad.
    We are at the very end of our SLAM. Our water has been perfect all year, but we let it slip last week when we had 5 days of rain. It got a slight green tint so we started the SLAM. We can see the bottom and it looks pretty good, just a little cloudy. The kids are begging to swim today, but the FC is 15 (our CYA is 30-40). Is it safe to let them swim with the FC that high or should I make them wait until the FC drops?
    This was split off the topic here:. This is why we say
    Orlando, FL
    690
    Re: This is why we say "Its not safe to swim if you can't see the bottom"
    An FC level of 15 will not hurt them but have you done the OCLT to make sure the problem is solved completely before you conclude the SLAM process.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Mar 2015
    Charlotte, NC
    8
    Yes, last night it only dropped .5. Do you think that is sufficient to let them swim? I was going to maintain an FC of 15 for another day or so just to be safe.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Safe to swim with high FC
    If it is safe to swim depends on your CYA level. If the FC is below shock level for your CYA, then yes, it's safe to swim.
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Right, it is safe to swim when your chlorine level is above the minimum and below the shock level for your CYA on the Chlorine CYA Chart
