Thread: Cleaning concrete?
    Jul 2014
    NJ
    123
    Cleaning concrete?
    When I opened up the pool, I noticed that my cover left a few rust stains (?) on my white concrete.
    Any suggestion on a good cleaner? Anything I can do about it?
    20x40 L-shape 35k gallons, Pentair FNS 60 SQFT DE Filter, Pentair Multi-port Valve, Hayward Super Pump w/1 glorious HP, Vinyl Liner, Dolphin Z5, TF-100 w/Speed Stir
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Re: Cleaning concrete?
    Bleach? CRL (calcium, rust , lime remover)
    CLR Calcium Lime Rust Remover - Walmart.com
    These are the first things I thought of. Good luck!
    Kim
    Jul 2014
    NJ
    123
    I never thought of using CLR on concrete. I wonder if that will work? No one has ever had this problem before?
    Jul 2012
    Tallahassee, FL
    30,672
    I do not close my pool so..............
    Maybe try a small spot well away from the pool to see what happens using CLR.
    I would make sure to have the water hose ready to rinse it away from the pool.
    Kim
