Thread: Suggestions needed for Spa (400 gal)
    May 2015
    Ten Mile, TN
    74
    Today I decided to use the Taylor test kit instead of indicator strips for the spa and here's what I got
    pH=7.6
    FC=3.0
    CC=2.5
    TA=40
    CYA=32
    CH=50
    The fiberglass hot tub is about 400 gallons and is covered most of the time. I add a little oxidizer and trichlor powder weekly. The water has been in there about a year. The last use of the spa was over a week ago.
    What to do about the high cc level?
    Should I slam the spa?
    I want to use the BBB plan soon (brisket, beer, and bathing)
    24' Round 14000 gal AG - installed June 2, 2015
    Saltwater Hayward AquaRite w/TCell - 9
    Waterway 26" sand filter w/ 2HP 2 speed pump
    Taylor K-2006 FAS-DPD Test kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Suggestions needed for Spa (400 gal)
    When you say you use oxidizer do you mean an MPS (Potassium Monopersulfate) product? If so one downside to these products is that it shows up as CC on the standard tests.
    As to what to do, I would suggest starting out with a fresh refill, in general hot tubs should be drained and refilled with fresh water at least 3 times per year if they are being used consistently.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    I would get some Ahh-some, Ahh-Some Water Cleanser, for pool, hut tub, jet bath, and washing machines, do a cleaning, drain and refill. Then use this process to maintain your tub. How do I use Chlorine in my Spa (or pool)?
    I've been using this method for a year and a half and I'm very happy with it.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Ahh some does seem to be a good product I would second this suggestion
    May 2015
    Ten Mile, TN
    74
    Yes---MPS.......
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Well that solves that CC mystery, I would still flush and refill, the Ahhh Some will help remove buildup and scum from the plumbing.
