Thread: Square spa design questions
    Jul 2014
    New England - MA
    310
    I'm curious how forum members with square spa's configured seating areas and steps. Would love some feedback before I start building our pool/spa. What do you love? What would you change?
    One thing I am considering is a different pebble finish in the spa. My pebble finish in the pool will be wetedge prism matrix. I was considering the wetedge Primera stone (a polished pebble finish) for the spa to reduce wear/tear on my wife and friends expensive bikinis...
    2015 Pool Build --> HERE IG 19'x47' w/ 7'x7' in pool spa; 3'6"-8' deep.
    Pentair 520 Filter, IntelliFlow VS XF Pump, IntelliChlor IC60 SWG, IntelliBrite/GloBrite LEDs, IntelliTouch w/Screenlogic2. 400K BTU heater. A&A G4V in-floor cleaning system. WetEdge Prism Matrix Pebble finish. TechoBloc Pavers and Coping.
    Test kits - Taylor K-2006 FAS/DPD, K-1766 Salt, SpeedStir
    38,284
    Re: Square spa design questions
    Sorry you have not gotten any quicker responses.
    I think I would want the steps in a corner since most people would not be sitting in a corner.
    Jul 2014
    New England - MA
    310
    Have been busy and unable to return to this question. They broke ground today. Guess it's time to stay my pool build thread.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I have an attached square spa. The spa is 7x7, it has jets on three of the four sides. Seating is designed for two people on each bench, so in accommodates six people as a spa or as a hot tub, eight (with two not having jets). My pool is PebbleTec, so to save on bathing suits, we had the seating benches tiled. The spa is at the same water level as my pool, so to step down into it there is a step set at a 45% angle across the corner where you enter.
    chiefwej
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    The wetedge install upcharge for changing finishes would probably buy a few swimsuits.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
