Results 1 to 9 of 9
Thread: Pool pump leaking oil?
    Sanman023's Avatar
    Mar 2009
    Sacramento, CA
    31
    A few days ago, I noticed that there is some kind of oil coming from the back side of the motor. I see an oil stain on the concrete right below. Is the motor going bad? I took the cap off and I can't seem to locate the leak. I will take a picture tomorrow.
    24,000 gallon pebbletec
    Hayward Swimclear cartridge filter C5025
    Hayward Northstar pump 2HP SP1620
    Hayward Navigator
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: Pool pump leaking oil?
    The only oil I can think of in a pump would be the grease in the sealed bearings. If it's leaking out, then it would be on the downhill slope. Listen for the bearings to begin getting loud and or the pump getting very hot.
    Support the site
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    yup.
    The bearings are sealed and packed with grease. If the seal is broken the grease will leak out.
    If you dont let it get too far, you can replace the bearings if you're handy, or take the pump to a motor repair shop and they can replace them.
    Divin Dave,
    Sanman023's Avatar
    Mar 2009
    Sacramento, CA
    31
    Thanks for the responses...the pump is about 8-9 years old....do you guys think it's more cost effective to replace it?..I'm thinking if I get it fixed I would still need to replace it in a few years...
    Hayward Navigator
    mas985's Avatar
    Pleasanton, CA
    11,741
    Do you have a spa? The pump is pretty big for just a pool. Might be a good time to downsize and go with a two speed.
    Mark
    Sanman023's Avatar
    Mar 2009
    Sacramento, CA
    31
    No spa...I have no clue why they installed a 2hp...maybe two waterfalls?
    Hayward Navigator
    mas985's Avatar
    Pleasanton, CA
    11,741
    Are they pretty big waterfalls? That might be the reason.
    Mark
    Sanman023's Avatar
    Mar 2009
    Sacramento, CA
    31
    Not too big...
    So I talked to a local pool service guy and he gave me 3 options...replace the gasket $100...replace with a refurbish pump $300 or replace with a new variable pump $1000-$1200...what do you guys think...
    Hayward Navigator
    mas985's Avatar
    Pleasanton, CA
    11,741
    Replace the gasket? That would be leaking water, not oil. Are you sure it isn't water that is leaking?
    Mark
