Results 1 to 9 of 9
Thread: New Solar cover from SolarCovers.com
    May 2015
    Louisville, KY
    55
    Ordered a New Solar cover from SolarCovers.com two days ago. They shipped it SAME DAY and I got it today.
    It appears that SolarCovers.com is the same as LeisureLiving.com and poolsupplies.com.
    I got it cut pretty easily with some regular household scissors and it looks great:
    I got the 16MIL CLEAR SOLAR COVER with free shipping. Very pleased so far.
    My pool has been losing about 4 degrees over night. Tonight the pool is 86, so we will see what it is in the morning.
    Pool: 13,500 Gallon, San Juan StarDust Inground Fiberglass, installed May 2015
    Filter: Pentair cartridge filter, Clean and clear plus
    Main pump: Pentair Intelliflow | Booster pump: Pentair 3/4hp
    Pool Cleaner: Polaris 280 | Chlorine generator: AquaCal Autopilot Digital Nano Plus
    Filled pool with city water & using TF-100 test kit
    Apr 2015
    Brookline
    60
    Re: New Solar cover from SolarCovers.com
    Were the dimensions of the 18x36 just that or did that oversize it?
    Southern New Hampshire, 18x36 single roman end pool.
    May 2008
    Northern California
    73
    I just installed the 12mil clear from the same company. Hoping this will prevent a lot of evaporation. I was a little disappointed that the bubbles did not look anything like the enlarged pic online.
    My 15'x30' was oversized, but not by much. Maybe 6-8" on each dimension.
    12,000 gal. IG Colorquartz, 1.65hp Sta-Rite with 2-spd motor, 300sf cartridge, disabled SWG, AquaLogic P4, Polaris 280, gas+solar, 6' sheer descent with dedicated pump
    Feb 2015
    Grand Rapids MI
    53
    Cover looks great. How do you plan on removing it and covering it back up each time? Did you get a reel, if so which one and how is it working for you?
    18,000 gallon in ground vinyl pool. Sand filter.
    May 2015
    Louisville, KY
    55
    Quote Originally Posted by jhamblett View Post
    Sorry I did not measure it. My pool is about 37 x 15 so I laid it on top of the pool and then cut to fit.
    Quote Originally Posted by jandersen13 View Post
    Good question. I did not get a reel because I really don't have a good place for one. We've tried the "roll it up" technique and that doesn't work. We've tried folding it like a towel and that seems to work the best.
    After a week of having the cover, I don't feel like it really warms up the water more (over NOT having a cover) during the day. This is just my observation, I don't have real data to support that opinion. But it definitely keeps the heat in over night. Only losing about 3 degrees per night. With no cover, lost about 5 degrees per night. Two degrees doesn't seem like a big difference but 84 is oh so much nicer than 82
    If anyone has a good "technique" for putting on and taking off a solar cover, I would like to hear it.
    Sep 2010
    Orange County, CA
    52
    I've also ordered from SolarCovers.com and found out it was LeisureLiving.com. However, if I remember right, the shipping policy is better if you order from SolarCovers.com (free shipping with not too much of a purchase).
    I've tried several things to take solar covers on/off and don't like any of them. This year I'm trying a chemical cover from SolarCovers.com. I really should measure my overnight heat loss, but I didn't measure the old covers, so I have no comparison.
    Southern CA 30K gal Pebble Pentair WhisperFlo 1HP 2 speed Hayward DE6020 filter Paramount Debris Canister Goldline/Hayward AquaRite Pro SWG (T-CELL 15) Sense & Dispense (acid) Pentair IntelliBrite 5G and GloBrite Inter-Fab G-Force slide Jandy deck jets Lion head spout Dolphin Premier Cleaner Taylor K-2006 test kit
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    901
    I have found that clear covers when put on my pool and left on heated up water very quickly, but also aided in growth of algae when left on for long period of time! 7-10 days...even when bringing chlorine up to as high as 18 ppm before going on vacation. Never had this issue
    With blue covers. Going back to that.
    Mar 2013
    Yucaipa CA
    87
    I found that cutting the covers up into about eight pieces really makes it easy to remove and install the cover by one person. Paint large numbers on them so as to be able to reinstall them in the correct order. I hung them on the fence and covered with white plastic when not on the pool. The only bad part was if the wind blew really hard it would flip over a couple of the pieces, but that wasn't a big as we don't have much wind where I live.
    skeeter
    47 yr old(1977) 18,000gal Kidney shaped 38ft long plaster Pool with built-in Spa, Pentair Intelliflo VS3050 Pump, Pentair 48sf DE filter, Raypack RP2100 gas heater. HTH 5-way test kit
    Jun 2011
    New Jersey
    149
    Quote Originally Posted by guytimes View Post
    Hey there, I have the exact same cover from the same company, purchase original one in 2011 but after last year bubbles were coming apart and I put a hole in it a couple seasons ago, last year it was no longer heating the pool that much. I decided to buy a new one this year and was able to get a discount from them. I have had great experience with temperature on my pool, it got really really warm with the solar cover on during the day, had in the high 90s on couple occasions. My biggest concern was lose of water due to evaporation during the night which this solar cover completely eliminated. I also purchased a reel form them and I also have a free form pool like you. As soon as I get my cover on I will take pictures to show you (I am still opening the pool and shocking). But basically its a roll up a reel and it stands about 4-5 feet from the edge on deep end, has some cover on both sides on the reel. Very easy to roll up the cover that way.
    Free Form Gunite Saltwater Pool, 29,000 Gallons, Jandy DEL60 Filter, Jandy AquaPure 1400 Chlorinator, Polaris 380 Cleaner, Attached HotTub.
