Thread: TA for Vinyl Pool
    Apr 2015
    South Central PA
    297
    TA for Vinyl Pool
    I seem to have my pool pretty well balanced (TF-100 kit)- FC=6, CC<.5, CYA=40, pH=7.5. However, TA is around 150. pH is very stable. I was reading in other posts where people were asking about reducing TA with a vinyl liner, and many of the responses were that TA is not as important with vinyl and not to worry too much. Is 150 pushing it, or what number should I target? The recommended level in the handy reference section is 70-90+, I definitely fall into the + category. I did wipe the tip of the 0009 reagent after each drop.
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: TA for Vinyl Pool
    Hi dodge.
    it is CH thats not all that much of a factor in a vinyl pool.
    TA is important in any pool.
    What TA does, is buffer the pH. There is no real TA value like there is for other stuff, and every pool is different. so there is a wide "recommended level".
    So whenever your pH is stable, then whatever the TA is is the correct TA for you. If you're happy with the pH, then there is no need to do anything to the TA.
    Divin Dave,
    Apr 2015
    South Central PA
    297
    Thanks! pH has been good for me, so that's what I like to hear...
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    excellent!
    Divin Dave,
