Thread: Cyanuric Acid Reducer
    May 2015
    Demorest, GA
    11
    For those of you that would prefer not to have to drain and replace your water, I saw a product today available in an Ace Hardware store. A gallon was $40 and I think I recall it stating a reduction of 60ppm per 10,000gal. There was no statement of ingredients, just patent pending.
    20,000 gal. vinyl chlorinated pool
    Cartridge filter
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Re: Cyanuric Acid Reducer
    If it is the same product I am thinking of there are quite a few threads about it in the deep end section here. Most say it doesn't work as well as it is advertised if I remember correctly.
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Quote Originally Posted by Scuba_Steve View Post
    That is correct. So far users who,have tested the product and conducted regular testing using recommended testing procedures were unable,to duplicate the manufacturer claims.
    Multiple threads are in the Deep End showing the test results.
    Support the site
    May 2015
    Pooler, GA
    311
    Bio-Active is the product I was mentioning. It is a live bacteria that eats CYA. Apparently you need low levels of FC for it to not die. I think most got about a 15-20ppm loss of CYA.
    TF-100
    Helpful Links
    There was a melamine based product that was discontinued a while back. Perhaps it's that. If you can post a picture, that would help.
    Support the site
