Results 1 to 10 of 10
Thread: Commercial Test Comparisons
    May 2015
    Demorest, GA
    11
    I did a comparison today of my local pool supply, my Ace Hardware Pool tests along with my new Taylor K-2006 test kit. Here are my results:
    Georgia Pool Supply Company;
    FC=0.3
    CC=0.3
    pH=7.8
    TA=169
    CH=180
    CYA=60
    Recommendations: 2.75lbs. Lo 'N Slo, 2 bags Burn Out 3
    Ace Hardware Pool Analysis
    FC=0.8
    CC=0.2
    pH=7.3
    TA=137
    CH=220
    CYA=45
    Recommendations: Add 1 gal. 1pt. 5.0oz. muraitic acid or 11lb.10.0oz. O-Ace-sis Minus and add 3.0oz. and =>O-Ace-sis Chlorinating sticks or tablets.
    My Test
    FC=1.2
    CC=0.2
    pH=7.2
    TA=150
    CH=200
    CYA=45
    As you can see the Ace Hardware tests seem to be more inline.
    I also noticed that Ace has a Cyanuric acid reducer available. I should probably make a new thread on this but it was $40gal. and stated a reduction of 60ppm per 10,000gal. if I recall correctly. It was of the O-Ace-sis brand name but did not state ingredients but a patent pending.
    20,000 gal. vinyl chlorinated pool
    Cartridge filter
    38,290
    Re: Commercial Test Comparisons
    Forget the pool store testing and the ace store testing we don't believe it anyways. Search the forum for the CYA reducer there are lots of them discussing how it is not apparently living up to the hype.
    Donldson's Avatar
    NW Ohio
    2,896
    Just another brick in the giant wall of evidence that we use to say get your own test kit. Even if Ace was close, what happens if you go in tomorrow and a new person is working the test counter? No way to know if they get it right or not without your own kit.
    As for CYA reducer, are you sure it wasn't chlorine reducer? AFAIK there is only one supposed CYA reducer on the market now, Bioactive, and it has been a real letdown. I didn't see anything on the O-Ace-sis website.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    30,421
    At this point, I think it's pretty safe to say a reliable CYA reducer doesn't exist.
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Sure there is. And it is very effective too! Add one gallon of it to one gallon of pool water and it will reduce your CYA by 50%.
    It is called TAP H2O
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Why did ace want you to add acid with a ph of 7.3?
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    Ace was right, you do need more chlorine!
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    One gallon of Acid in 20K with a current pH of 7.3? A shining example of why NOT to trust these vendors.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    Yeah, wow, do the poolmath on that!
    whataboy's Avatar
    Jan 2015
    Lewisville,Texas
    53
    Quote Originally Posted by Patrick_B View Post
    I bet pool stores have screwed up more pools then one could imagine. That's their way of selling you more junk you don't need at all especially if you go the BBB route.
    Glad I found this site the same time I purchased house with pool. Had it re-plastered 6 weeks ago and couldn't ask for more perfect water using the BBB method. All numbers are spot on. Of course I treat it like a new born baby...
    Rick T.
    12,000 gallon IG Kidney shape,gunite,white plaster w/25% blue quartz (Chlorine)
    Jandy LED Multi-color pool light, ,Pentair VS Pump,Pentair FNS 48 DE Filter,Polaris 280 Cleaner
    TF-100 test kit, Taylor K-2006 test kit, Speed Stir, BBB Method, PoolMath, TFPC
