Advice on CYA level and chlorine loss during the day
So I've been using the TFP method for sveral weeks now and my pool is crystal clear. I already did a SLAM and the OCLT is 1ppm or less. My CYA level is 30-35 and I lose 3-4ppm of chlorine everyday with the solar cover on. Should I increase my CYA level or leave it alone. I'm new to this and adding 40-65oz of bleach a day seems like a lot.
Thanks!
Latest results:
CYA 30-35
FC 4 (maintaining this level everyday)
CC 0
pH 7.5
TA 120
OCLT <1
Filter runs 6hrs
Solar cover on
7+hrs direct sun
Looks like you could raise the CYA slightly. You have about 15 to play with in your recommended levels window. I just did the same here to save on FC loss. Start easy though so you don't over-shoot 50. A little increase in CYA should tell you if it's working. More advise perhaps to follow. Overall though - great numbers!
