Results 1 to 9 of 9
Thread: Filter pump conversion
    Apr 2015
    New Bedford, MA
    65
    So I finally got all the stuff that I need to convert my summer escape pump to the intex krystal clear 2800 sand filter..apparently my genius husband and father put wood planks across the pool to keep the pool cover from sinking it worked but no one mentioned the wood planks had paint on them so now my pool has paint clippings all in it..we are in the process of just draining the whole pool there's no way I can clean this..so far we grinded the bottom of the skimmer basket uploadfromtaptalk1433552976885.jpg.
    14x42 summer escape metal frame pool with 2800 gph intex sand filter pump
    summer scape metal frame AG pool 14x42, 3750 gallons
    INTEX Krystal Clear 2800 GPH sand filter pump
    TF-100 Test Kit Pool Calculator , cya-chart
    Pool school,recommended-levels
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Filter pump conversion
    Keep us posted on your progress.
    Support the site
    Apr 2015
    New Bedford, MA
    65
    The bottom of the pool is a mess I don't even know how I'm going to get this all cleaned I'm thinking going in there with a set vac and vacuum all the stuff out
    Apr 2015
    New Bedford, MA
    65
    I'm going to brush the walls as well
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Mmm, tasty! We did that once.
    Apr 2015
    New Bedford, MA
    65
    Quote Originally Posted by pooldv View Post
    How did you clean it
    Apr 2015
    New Bedford, MA
    65
    Pool is clean. We finished cutting the bottom of the skimmer and the strainer and plunger looks good so far no leaks
    http://www.troublefreepool.com/calc.html
    DFW, TX
    24,483
    Quote Originally Posted by angelover02740 View Post
    We took down a couple of uprights and used a broom and a hose to get most of it outta there. I've seen some people use big plastic shovels to scoop it out.
    Apr 2015
    New Bedford, MA
    65
    Did the same thing at first we used a wet vac but that was taking to long
