Results 1 to 8 of 8
Thread: Intellibrite Controller, Help!!!
    Jun 2015
    navarre
    3
    What gives, the controller has a red, black and white. My wall switch has black (120V HOT) and white. Can someone dum this down for me It Is Kicking my assss!!!
    Thank you for your time, Matt
    38,514
    Re: Intellibrite Controller, Help!!!
    Welcome to TFP!!!
    I would have to find and read the instructions .... so I will leave that exercise to you
    Jun 2015
    navarre
    3
    Looks nothing like I have!!!!
    38,514
    Looks like you do not have enough wires in your outlet.
    You need to have power to the controller and then be able to send power (from the red wire) to the light fixture itself.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    hmmm, where are you trying to connect it? That looks like a wall switch for an outside porch light.. how many wires do you have coming from the light? where are you pulling power from? it should be a GFCI breaker...
    This diagram shows exactly how to connect it up http://www.pentairpool.com/pdfs/Inte...ntrollerIG.pdf
    Jun 2015
    navarre
    3
    That'zzz what I was seeing I need to add a true neutral and loop It into the junction box from the transformer.
    38,514
    I do not follow what you just said.
    What is that romex in the outlet box? Power supply from the house?
    If so, then you need a 120V power wire run from the outlet box to the 120V light fixture or 12V transformer box.
    I wonder if the op has power on the black and the white goes to the light and the lights neutral is tied in elsewhere....
