Thread: Question about CYA in sock method
    Mar 2015
    Chesapeake/VA
    5
    I have a question about the powder/granules in the sock method, as that is how I do it. Are you saying that if I add via the sock method and then remove the sock, the cya may continue to rise even though I removed the sock?
    Say I put the sock in for 4 days then removed it, I would think all cya would be in solution, or are there small undissolved cya in the pool/filter that will continue to dissolve?
    I also use a Dolphin with 2 micron robot very frequently - would this remove any small undissolved cya particles ( small enough to get out of the sock but not past the 2 micron filter. I would also think any small particles that got into the robot would dissolve quickly as the flow thru the robot is high.
    38,271
    Re: Question about CYA in sock method
    Yes, the CYA may continue to break down even after it is out of the sock.
    Not sure if the robot would capture the dissolving CYA, but I agree if it did, the water flow should help dissolve it.
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    After 4 days the CYA should all be in solution. After 1 day... not so much. That is why it is said around here to wait 4 days to a week to test.
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    Jun 2014
    Scott City, MO 63780
    5
    To help get your powdered CYA into your pool faster, put it into a large pan of boiling water, and stir, quite a bit of it will dissolve, pour water portion into the skimmer, put un dissolved into women's hose, hang it where the water is moving with pump running and it will dissipate fairly quickly. This works great if you need to add several pounds to bring up your reading
    38,271
    Quote Originally Posted by semo View Post
    So now we are playing with boiling water
    This just sounds like extra unneeded work. You can get it dissolved out of a sock in a few days, not sure there is enough of a hurry to warrant sauteing the CYA.
