im trying to install a new intelliflo vs to a compool ez touch upgrade.. the comm wire DOES go to the 4 wire terminals on the comm port using the yellow and green. right?? dang, i cant get it to communicate. any ideas???
I looked in my manual and in every case I can see the com wire from the pump connects yellow to yellow and green to green, just like you said. I did see where the manual says "The Easytouch will not start communicating with the pump until the pump is assigned to a circuit." Have you gone into the Easytouch and set the pump type to VS?
