Thread: hooking up an intelliflo to an ez touch upgrade
    Jun 2015
    Bradenton
    1
    im trying to install a new intelliflo vs to a compool ez touch upgrade.. the comm wire DOES go to the 4 wire terminals on the comm port using the yellow and green. right?? dang, i cant get it to communicate. any ideas???
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,448
    Re: hooking up an intelliflo to an ez touch upgrade
    I looked in my manual and in every case I can see the com wire from the pump connects yellow to yellow and green to green, just like you said. I did see where the manual says "The Easytouch will not start communicating with the pump until the pump is assigned to a circuit." Have you gone into the Easytouch and set the pump type to VS?
    Jim R
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Yep, you have to program the easytouch to tell it that it is controlling a VS intelliflo. Then it will control it.
