Results 1 to 13 of 13
Thread: Hayward Aquarite
    Sep 2007
    Florida
    16
    Hayward Aquarite
    My PPM is 4k. I was told by Hayward to drain some of the pool and run the hose, which I did. I added more water today and it still says 4k?
    Suggestions?
    Scott From Florida
    38,342
    Re: Hayward Aquarite
    Have you independently tested the salt level? At least that is what I assume you are asking about.
    Sounds like the salt is still too high, although can take a day for the SWG to get a new reading.
    Sep 2007
    Florida
    16
    Yes, the other day and it said 4k as well.
    But I have added a bunch of water...
    Scott From Florida
    38,342
    What is "it"
    Sep 2007
    Florida
    16
    I took it to 'Pinch a penny' pool store.
    Scott From Florida
    38,342
    We generally do not trust pool store testing ... and if you have gotten 2 readings for salt that were the same after you replaced water, then I think you should see why.
    What salt level does the SWG say?
    Please add your location (City, State or City, Country) to your profile and pool details to your signature as described HERE as it will help us help you.
    Sep 2007
    Florida
    16
    At first glance, the reading is 4200. The instant salt level is 3500.
    Scott From Florida
    38,342
    If it is not complaining about high salt ... then leave it. Since the instant is lower, the average should come down.
    Jun 2011
    Long Beach, CA
    2,790
    What level does the instant salinity say it is when you go through the diagnostics? Is the Aqua Rite giving a high salt error? If the test and SWG say the salinity is 4000, then the only fix is to drain about 25% of the water.
    Sep 2007
    Florida
    16
    Ping, see my previous post above.
    Between yesterday and today, I did that.
    Scott From Florida
    As long as the amps don't get to 8, it should not trigger a high salt error or shutdown. To reset the average, you can go to the instant salt reading and move the switch from auto to superchlorinate and back to auto. However, it should not be necessary unless it shuts down with a high salt error.
    Support the site
    Feb 2014
    Upstate, NY
    390
    I would use the Taylor 1776 salt test kit. Forget the pool store testing as mentioned. The reading on the Aquarite is +/- 400 PPM. Again, you need to test independently of the pool store and the actual reading on the Aquarite.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    You can look in the new instant salt level 3500 very easily. Or you can wait for the averaging of the unit to come down over time. Here are the directions to look in the new instant salt level.
    1. Slide the Main Switch to the "Auto" position.
    2. Push the Diagnostic button repeatedly until "-xxxx ppm" appears on the display.
    3. Slide the Main Switch from "Auto" to "Super Chlorinate" and back to "Auto".
    4. Push the Diagnostic button to exit.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
