Thread: Backwash
    May 2015
    Burlington, Wa
    8
    Backwash
    Im in my 2nd day of slam, the filter needs backwashing, PSI is 10 pounds above avarage, filter housing at pump can only fill halfway with water.
    Do I leave it because a dirty filter cleans better or backwash to get more water flow?
    Thanks wgcole
    22,000 Inground, 8' deep,Diving board,Slide,Tagelus Deluxe TA-60D, 3/4 HP pump, Teledyne Laars 250,000 BTU Heater, Heliotrope General Model HM4000A Heating Collectors
    38,524
    Re: Backwash
    You should always backwash when the pressure rises 20-25% over the clean pressure ... waiting for a 10 psi rise is way too long.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: Backwash
    Backwash.
    We don't know what your normal pressure is, but we recommend backwashing when it goes up 25%. I seriously doubt your filter runs above 40 psi normally. So it's time to backwash.
