Thread: Compatible replacement for old Hayward Lights
    May 2014
    South NJ
    4
    I have old pool (built in 1988) with Hayward Pool Lights Model SP0540. I already replaced them once. One of the lights lived for one or two seasons and now it is not working again although was not used much at all. I would like to find a LED light replacement but have hard time to find one that will fit into the existing housing. It looks like the niche for this light is SP0555 or similar. It is not very dip (6 7/8) has lower mounting screw and screwed on the top to the wall. The face rim is 10 7/8 outside diameter.
    Can someone let me know what my options are? Are there any new Hayward light models or other that can be used with this niche or if there are adapters that I can install?
    Thanks in advance for help.
    30000-gallon IG concrete/plaster pool, Pentair DE Stainless 48" filter
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Re: Compatible replacement for old Hayward Lights
    Good day, the only light that will fit into a SP0555 niche is the SP0570 series. This light comes in 12v 100 or 300 wt, or 120v 300 or 500 watt.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
