Results 1 to 9 of 9
Thread: New Pool Owner
    Jun 2015
    Cleveland, Ohio
    3
    New Pool Owner
    Hi, I'm a new pool owner in NE Ohio. Pool is up and filling, have a temporary extension cord running to the pump and am waiting for the County to approve the electrical permit.
    The pool store we bought the pool from included a Frog Leap Infuser which from everything I've read about is garbage and I'm not going to use except maybe the trichlor for vacations. Not even installing the mineral pack. They gave me a bunch of other things in a pool opening kit. A couple of bottles of zinc based algaecide which I assume I shouldn't use. Some MPS shock, a metal "remover" (I'm assuming this is a metal sequestor which I probably wouldn't need), and a couple bags of Calcium Hypochlorite shock.
    I have a TF-100 test kit coming in the mail on Tuesday I plan on starting the motor later today once the water is at the right level. Should I do anything as far as chlorine goes until I get my TF-100 on Tuesday?
    14,250 Gallon AG 24' 54" Aluminum pool. NE Ohio |Waterway Clearwater II Cartridge Deluxe System 1.5 hp 2 spd pump.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: New Pool Owner
    Welcome to,TFP!
    If you have water, you need chlorine.
    Use Pool Math to compute how much stabilizer you are going to need and put half that amount in a sock and hang it in front of a return.
    Add about 1/2 gallon of bleach each morning until you get your test kit and can be more precise.
    Support the site
    Jun 2014
    15,148
    Re: New Pool Owner
    Vermifax, I'm impressed. You speak good TFP and know to stay clear of those "products" pool stores/builders try to push on you. You have good instinct. Not to mention already having the TF-100 on order! Outstanding! If you haven't seen the pages/link listed below in my sig, please do so. You'll be that much more ahead of the game. Welcome to TFP!
    May 2013
    Ontario, Canada
    63
    Re: New Pool Owner
    I would also get some CYA in a sock (at least 1lb) to start it off and maintain some of that bleach.
    18' x 36' vinyl steel wall pool with deep end, 2 lights and 6' steps, main drain, SWG, Cartridge Filter, 320,000 BTU Rheem heater, 3/4HP 1 stage pump - Ontario, Canada
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: New Pool Owner
    Welcome to TFP. Sounds like you've already done some homework.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: New Pool Owner
    Welcome to TFP! Congrats on the new pool!
    The two most important things to maintain in your pool day to day is chlorine and PH.
    PH needs to be kept between 7.2 and 7.8 always.
    Chlorine needs to always be kept above the minimum level for your CYA level to keep algae from growing. Chlorine CYA Chart
    Jun 2015
    Cleveland, Ohio
    3
    Re: New Pool Owner
    Quote Originally Posted by carpenter333 View Post
    Is that a literal cotton foot sock? Or something else?
    Thanks everyone for the advice.
    April's Avatar
    Apr 2014
    KY
    138
    Re: New Pool Owner
    Quote Originally Posted by Vermifax View Post
    Yes it is. I use one of my husbands old socks.
    18ft Round AG, Vinyl, 100LB Pentair Sand Filter, 1HP, June 2012, TF-100 w/SpeedStir
    DFW, TX
    24,497
    Re: New Pool Owner
    Make sure there aren't any holes! I stole one of the kid's loner tube socks.
