Thread: Algae/dust dilemma
    Algae/dust dilemma
    Trying to deal with possible algae issue will do the OCLT tonight, but would like to bump up my chlorine levels today just in case. Brown stuff on bottom and sides of pool, brushes up, water a little cloudy, have had lots of debris from the 500 trees around our place. My question is what is my SLAM FC number with a CYA level at 0 and a SWG? CYA is a pain in my backside--I am afraid to get it too high so I end up adding it very slowly, so slowly in fact that I have never seen the dot disappear despite the liquid running out of the top of the cylinder. I am hoping someone will help me here are my other numbers and pool info. This is my 4th year with our pool, which my husband and I built ourselves from a kit. Have learned a lot--mostly what we should have done as opposed to what we did--have used the test kits (TF 100) and methods recommended on this site since day one and my pool has looked great!
    FC: 1.5
    CC: .5
    CYA: 0
    PH: 7.6
    Pool Info: 20x40 in ground, 1.5 Hayward super pump, 24T sand filter, Aqua rite SWG, Hayward 400,000 BTU heater
    Here's our little oasis in Iowa:
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Algae/dust dilemma
    Right now with no CYA you don't want to go higher than 4ppm. You need to add Stablizer to a sock for a target of 30 and set it in top of a skimmer to disolve. Leave the filter running and squeeze the sock to help it disolve. Once dissolved you can SLAM to 12ppm. Don't test CYA again for 1 week as it won't fully show up for one week. Right now all your FC is being consumed by the sun and probably algae bloom trying to kick in.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    30,415
    Welcome to the forum.
    I'm gonna modify AZgirl's good advice just a little. With hot summer days coming in Iowa, I suggest you calculate and add enough CYA to get to 40 ppm. If you are really worried about overdosing, post back up your intended dosage and many of us will confirm.
    Once you dose the CYA, you can SLAM to 16 ppm FC but I am not sure you need to SLAM at all......your water looks beautiful. So does your house.....old farm house??
    Jun 2014
    15,066
    Welcome to TFP! Feel free to refer to the links you see above/below in many of our signature fields as they contain some of the info you were specifically asking about. Might save you some time. As always, if you have any more questions, just ask. As you can see, there are many TFP'ers just a mouse-click away. Have a great swimming season!
    Thanks, but not actually a pic from today!! I will try to get one with the algae/dust stuff for expert diagnosis. Yes, our house is an old farm house--my husband's family bought the farm in 1905.
    I will boost my FC a little to 4 and I will get going on the CYA--how often do you guys squeeze it? I have tried that, but it seems like it still takes forever to dissolve. Thanks for the help!!! Timi
    20' X 4' Round AGP KD Pool - 8200 gal.
    1.5 Dynamo Pump with Pentair Sand Dollar Filter
    Intex CS8110 SWG
    Gulf Stream HE90 Heat Pump
    Jun 2014
    15,066
    I just put some stabilizer in my pool via the sock method. I just went by every couple hours or so and gave it a few squeezes in front of the skimmer. In my case, it took about a day to dissolve completely.
