Thread: Adding DE to sand filter?
    Mar 2015
    Gainesville,FL
    5
    I read about how you can add some DE mixed with water into the skimmer to increase the sand filter's ability to catch small stuff. So I did that, it took a cup to increase the PSI by 1 lb.
    Do I need to add DE each time I backwash? IE does it get washed out when I backwash? Any other tips?
    Byra
    18,000 Gallon in ground pool with SWG
    Plaster surface, Maytronics Z5 robot
    Multi speed pump, Hayward sand filter
    TF-100 test kit
    K-1766 salt test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Adding DE to sand filter?
    Yes, it needs to be replenished. It forms a superfine layer on top of the sand. In relative terms, like putting window screen over chicken wire. Expect your pressure to rise fast and need a backwash.
