Thread: salt water generator
    Mar 2014
    florida
    4
    have not used salt gen. for about 9 months,been using chlorine instead because of surgery.cannot pick up bags of salt.will I damage salt unit by not using it.thank you George.unit is only about 2 years old.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Re: salt water generator
    Hi George,
    As long as the SWG is not powered up, it should be fine.
    hope this helps and hope to see you up and around soon!
    Divin Dave,
