Thread: Pool water readings
    Jun 2015
    Mobile, Al
    2
    Pool water readings
    My test on my pool is ph 8.2, TA 160, an CL at 5-10. Is this ok?
    I have an in ground pool. 23k of water. Vinyl liner, ranger series sand filter with Pentar model 320 automatic chlorine/bromine in- line feeder and Polaris robot pool cleaner and a Leslie's deluxe pool care DPD test kit.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Pool water readings
    Welcome to TFP!
    Why do you say the FC is 5 - 10. Which is it?
    Plus, without the CYA the chlorine number is useless
    Support the site
    Jun 2015
    Mobile, Al
    2
    Well on the test kit it has 5 10 and it is same color as that range. What is CYA?
    38,290
    Welcome to TFP!!!
    10ppm is if you had bromine, 5ppm is chlorine ... does not sound like you are using one of the Recommended Test Kits with the FAS-DPD chlorine test.
    Please take a look at this to answer your last question:
    ABCs of Water Chemistry
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by cbyrd View Post
    it is another name for stabilizer. If you have the Leslie's DPD test kit has a CYA test, you need to run it to find out your level. That kit is the same as a K-2005, so you need to add the FAS/DPD test to be able to test above 5
    TFTestkits.net
    Support the site
    Donldson's Avatar
    NW Ohio
    2,896
    Welcome to TFP!
    Your pH needs to come down, but that is just about the only advice I can offer without more tests. CYA and proper FC readings specifically. 5-10 is not nearly accurate or precise enough and one of several reasons we do not like test strips.
    How does your water look?
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
