Results 1 to 12 of 12
Thread: Bleach Causing Film?
    May 2015
    Troy, Ohio
    30
    The pool guy just left after installing our light & he said that we have a film on the top of our water from using store brand bleach instead of actual pool chlorine. He said it's from soap that's in the bleach. I'm assuming that's not true since using bleach is one of the basic things that TFP recommends. Is what he said just baloney or am I using a bad kind of bleach? I am using Walmart's 8.25% 121 oz. basic stuff.
    Thank you!
    Kelly
    32x16 rectangular vinyl in-ground pool (21,000-23,000 gallons?) filled with well water. 24" Hayward sand filter & a Hayward super pump (unsure of model # or specifications). TF-100 test kit.
    Jun 2014
    15,255
    Re: Bleach Causing Film?
    I'm going with Grade-A bologna. Sodium hypochlorite is the active ingredient - period. Probably another reason why we try to encourage pool owners to just take care of the pool themselves because sometimes they fall victim to such comments. At least you had to good presence of mind to know better and ask for validation. Good for you!
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    I've never had a film on my water and I do use Walmart Bleach. Sounds like you already know NOT to use Splashless, Easy Pour, Scented. Use regular 8.25% bleach.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    Donldson's Avatar
    NW Ohio
    2,917
    2 questions:
    1. Do you notice any film on top of your water?
    2. How does he know you are using bleach?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    May 2015
    Troy, Ohio
    30
    Thanks to everyone for reassuring me! I'm pretty sure that there is no film. Our water still a little cloudy because we are trying to get the chemicals straight and the pool guy saw my gallons of bleach sitting out (oops!). I think I'll take his advise with a grain of salt. Thanks again!
    Kelly
    Mar 2015
    Georgia
    157
    I use Regular Great Value 8.25% also. Never had a film here.
    16k AG Vinyl Sand Filter
    Casey's Avatar
    SW PA
    10,461
    Never had an issue with film until hubby introduced his oiled body into the pool. lol
    Your pool boy is full of it!
    Donldson's Avatar
    NW Ohio
    2,917
    Yeah, I am guessing he saw the bleach and then came up with his film story. Now if he hadn't seen the bleach and asked if you were using it, then he might have had some credibility.
    From my HTC One via Tapatalk
    30,432
    Quite the opposite....ordinary bleach is the cure for any films that may develop on your pool.
    lmnconn's Avatar
    May 2014
    Missouri
    35
    That's funny. If you are adding your own chemicals, what does your pool guy do?
    St. Louis, MO, 25000 gal, 16x32 lagoon, vinyl, sand filter, Hayward pump, chlorine, install complete 9/12, Taylor TF100 test kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Hopefully run skimmers, brush, vacuum, and leave.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Quote Originally Posted by Patrick_B View Post
    LOL! Good plan!
