Thread: Pool valve handle needed
    Hello
    I have kbi pool valves and need a handle only
    Thanks in advance
    Tom
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pool valve handle needed
    A lot of times those valves get bound up inside which causes the handle to break. They are the source of a lot of cussing. If you replace the valves, get the Jandy Never-Lube. The price will shock you, but you won't regret it.
    Thanks John
    Valve is working ok now. Was dry as I just opened pool a couple of weeks ago. I read if the ball valve is dry it may be harder to turn. I'm using a wrench for now
    Tom
