View Poll Results: What depth?
Voters
16. You may not vote on this poll
  • 4' sloped to 6' deep
    9 56.25%
  • 4' edges slopping to 5' deep center
    7 43.75%
Thread: Need help deciding!
    Jun 2015
    Dallas. TX
    59
    Need help deciding!
    Hello everyone!! We are in the process of planning and designing our pool. It is just us two (30ish) with no plans for kiddo's so we don't need diving boards, etc.
    What we can't decide is depth! Husband is 6'2" and I'm 5'3". Our layout is geometric (rectangle), so the question is - should we get a pool that is 4' sloping to 6' in the deep end OR 4' on both ends with the center being the deepest point at 5'.
    We are not overly playful, we may occasionally want to play water sports but mostly like lounging and hanging out.
    What do you think?
    No pool yet...will update once we sign the dotted line and begin construction :)
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Need help deciding!
    Welcome to TFP!
    Even a 5' pool is pretty shallow. The water will be shallower than that most of the time. I'm 6' and usually stand out near where the bottom is 6' below the deck to stay cool.
    Jun 2014
    15,298
    Our pool is rated at 7' deep, although to the water line it is actually a little over 6.5' and we love it. Our pool is long enough to where we have plenty of shallow standing room to chat or play volleyball, yet also be able to swim down deeper if we want. We don't dive either, but I think the deeper water helps to keep the overall pool temperature at a more constant, pleasurable temp. That could just be my imagination, but I'm sticking to it!
    Jun 2011
    Long Beach, CA
    2,790
    I would go for the 6' section as it will absorb some of the plunge if you want to jump in the pool. I've jumped into enough shallow pools to know how much of a difference a foot makes on my damaged knees. There will be plenty enough shallow space with a 4',6',4' pool.
    May 2015
    Fullerton, CA
    639
    going through the same process, I think 4-6 is the best. I am 6,2" wife 5,3" She wanted 3.5-5. I think that's way too shallow, 4-6 is the a good compromise.
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    Jun 2015
    Dallas. TX
    59
    The most ironic part is that I (the short one) want the 4'-6' and my husband wants the 4-5-4
    I think I will try to convince him to go 6' based on the water line being shorter than the chosen depth
